Old 09-19-2009, 04:08 PM   #1
PDW HOTRODS
PDW HOTRODS's Avatar
Bed block size?
Does anyone know what size the bed mount wood blocks are? Thanks.
PDW HOTRODS is offline   Reply With Quote
Old 09-19-2009, 05:00 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Bed block size?
What?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-19-2009, 05:34 PM   #3
PDW HOTRODS
Re: Bed block size?
On a 1953 style pickup, where the bed mounts to the frame, there are wood blocks used as spacers between the frame, and the bed. I was wanting to know the exact size they are suposed to be. Mine were rotted away so I couldn't mesure them. I want to use steel instead of wood.
Old 09-19-2009, 07:44 PM   #4
sn33kyp3t3
sn33kyp3t3's Avatar
Re: Bed block size?
Yes I would like to know as well. Haven't gotten that far yet, but good to know.
sn33kyp3t3 is offline   Reply With Quote
Old 09-19-2009, 07:53 PM   #5
sgtusmc
sgtusmc's Avatar
Re: Bed block size?
I might still have mine. I'll see if I can't dig them up.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 09-19-2009, 10:02 PM   #6
Atomsplitter
Atomsplitter's Avatar
Re: Bed block size?
The set I have are aftermarket but the dimensions are:
2-5/16" high x 2-3/8" long x 1-3/4" wide
Atomsplitter is offline   Reply With Quote
Old 09-19-2009, 10:23 PM   #7
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
Re: Bed block size?
PDW, it depends on your cross sills. The important thing is the stacked up height of each cross sill and its wood blocks should be the same height as the rear sill mounting brackets. Original cross sills were a little over 1-7/8" tall including the bracket and the rear sill bracket is 4" tall. Typically 2-1/8" would be a starting point, but measuring on your truck is best. The bed should sit level on the frame and all mounting points equally share the support of the bed when installed. If your frame is tweaked so the bed to frame mounting points are not all exactly in the same plane, you may have to adjust some points up or down to accomplish this. The sketch in this instruction http://www.mar-k.com/bed_mounting_information.pdf will illustrate the idea.
Mar-Ktech
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 09-19-2009, 10:40 PM   #8
sn33kyp3t3
sn33kyp3t3's Avatar
Re: Bed block size?
Mar-Ktech
Great info there. Thanks for that.
Old 09-20-2009, 12:22 AM   #9
PDW HOTRODS
Re: Bed block size?
Thanks. My frame is good, and I thought a little over 2 inch should work. I have to add a little extra though. I got a new front bed pannel, and the hight was not correct. The tailgate was terrible also. I returned the tailgate, but I did not notice how far off the front pannel was, so I kept it. I got a new tailgate from Mar-k, it was very nice, and I wish I had goten a new front pannel from them also. I guess I lerned a lesson there.
