Old 09-19-2009, 05:09 PM   #1
Rodd Zane
Switch from manual to auto transmission
I've got a 68 Chevy 2 wheel drive 1/2 ton truck with a manual 3 on the tree. I want to swap to a auto probably a 350, will the existing cross member work with that trans? Also some one told me the dive shaft will work, any thoughts?
Ken
Rodd Zane is offline   Reply With Quote
Old 09-19-2009, 05:13 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Switch from manual to auto transmission
your 3 speed doesn't have a crossmember, just mounts to the bellhousing.
You'll need;
Crossmember
tranny
torque converter
speedo cable
tranny mount
most likely driveshaft or mods to yours
Kickdown cable
cooler lines
shifter linkages
auto column
radiator with trans cooler
Old 09-19-2009, 05:15 PM   #3
Skirkpat
Skirkpat's Avatar
the crossmember that the bellhousing bolts to will need to be removed (8 rivits), an automatic trans cross member will need to be found, if you use an 9 inch tail housing T350 you can use your driveshaft "I think" just measure before you buy the automatic,there are 3 different lengths 6,9, and 12 in tailhousings. good luck!!
1969 Short Stepside
1969 4 WD Suburban
1970 1 Ton Dually....Misfit
oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door
Skirkpat is offline   Reply With Quote
Old 09-19-2009, 05:15 PM   #4
Smitty
Smitty's Avatar
I think that the last item Longhorn meant was a radiator with the trans cooler!
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 09-19-2009, 05:18 PM   #5
Rodd Zane
Do they make aftermarket crossmember?
Old 09-19-2009, 05:32 PM   #6
Rodd Zane
Does anyone know what year crossmember will work with the 68
Old 09-19-2009, 05:36 PM   #7
Longhorn Man
thanks i fixed it.
Old 09-19-2009, 05:41 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Th350 lengths are 6, 9, and 12
Old 09-19-2009, 06:32 PM   #9
Smitty
Smitty's Avatar
You surprised be there Longhorn! Thought maybe it was because I didn't have my glasses on.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Old 09-19-2009, 06:46 PM   #10
john
member #16
john's Avatar
Welcome to the board. To answer your ? yes there is an aftermarket X member. I would look on the parts board for a good used one, probably cheaper. heres a link to ECE.
http://www.earlyclassic.com/catalog.aspx
john is offline   Reply With Quote
Old 09-19-2009, 09:04 PM   #11
Skirkpat
Skirkpat's Avatar
ooop's, thank's for catching that. I fixed it.
1969 Short Stepside
1969 4 WD Suburban
Old 09-19-2009, 09:04 PM   #12
Skirkpat
Skirkpat's Avatar
ooop's, thank's for catching that. I fixed it. I knew it was a multiple
1969 Short Stepside
1969 4 WD Suburban
Old 09-19-2009, 09:06 PM   #13
Skirkpat
Skirkpat's Avatar
Thank you sir, I fixed my mistake....
1969 Short Stepside
1969 4 WD Suburban
Old 09-20-2009, 12:04 AM   #14
Terakilla
Terakilla's Avatar
I have a LS motor with a 4L60-E trans. Had to move new motor back 2 inches for newer single piece straight driveshaft and just used a piece of angle iron for a trans member, no problems so far and free, C Chanel will work too. If u wanna use the old driveshaftll it'll have to be cut, maybe find one off a caprice or similer like I did about the right length.
Terakilla is offline   Reply With Quote
