09-19-2009, 11:18 PM | #1 |
60-66 Nut
Roller Cam Thrust Button
We're still working on assembling my son's 406 and we're having a little issue with the cam thrust button. We're running a Comp hydraulic roller, Cloyes timing set, and a Comp 200 roller thrust button. The problem is with the cam, timing set and thrust button in place, when we go to put the timing cover on, the cover makes contact with the button, but it is almost 1/8" from the front of the block. We tried both a stock timing cover and a Milodon reinforced cover, and both are the same. This is my first time installing a retro roller, but I was under the assumption that it would need shimmed to get ~.008 endplay. Is it common to have to 'grind' on the button? that just doesn't seem to me like a good idea with a roller button. The books we have don't explain much and I've tried searching online for some answers with no luck. Can someone here help us out? TIA
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-19-2009 at 11:28 PM. |
09-20-2009, 12:55 AM | #2 |
Re: Roller Cam Thrust Button
dent or grind the cover, it will be hidden and coverd by the water pump any how.
measure the button and call summit to see if they have a shorter one. |
09-20-2009, 08:30 AM | #3 |
Had the same problem in my BBC, went through 2 dist. gears before I realized the problem. I used a Edelbrock cast alum. cover and clearanced inside. Next build I'm gonna clearance the button.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
09-20-2009, 08:31 AM | #4 |
A two/three piece timing cover should provide the proper distance, but obviously more expensive.
I would massage the cover before I grind anything.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
09-20-2009, 10:45 AM | #5 |
Registered Truck Offender
A cloyes Quick button timing cover will solve all your problems. The hex-adjust timing set and a Quick-button cover is all I'll use on a roller SBC. It ought to be law IMO.
Myself I'd be cautious of altering the cover in any way. The Milidon covers are reinforced to help support the thrust of the cam, and a stock (or the POS chromed junk) stamped steel cover on a roller motor is just a bad idea IMO. You need all the support you can get there to keep the cover from flexing. Most of the good cam buttons are steel with a shim pack / torrington bearing so you can adjust the 'fit'. Or there soft aluminum, cost a few bucks and I'd for sure stick it in a drill / lathe and make it fit the clearance before I'd alter anything else. But again..... that's just if you refuse to spend the bucks for the quick-button / Hex-adjust.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 09-20-2009 at 10:52 AM. |
09-20-2009, 01:27 PM | #6 |
I am still using stock cover and welded my washer to the cover but it would'nt pull up to the block so I laid it on a probably 2" socket and gave it a good smack with the hammer till it fit .And they do make different buttons.
Built chevy tuff! Last edited by Rodms; 09-20-2009 at 01:29 PM. Reason: add |
09-20-2009, 11:17 PM | #7 |
60-66 Nut
Thanks for all the replies guys.
We're a little baffled as to why this turned into a problem. As common as a SBC with a retro roller is, you would think that you could buy a thrust button that fits without having to 'massage' a timing cover. After some discussion it looks like the Cloyes Quick Button cover is the most appealing option. My son is going to order one tomorrow.
09-20-2009, 11:44 PM | #8 |
At the body shop.
What retro roller are you running. I got hr 288 comp cams and love it.
09-21-2009, 01:36 AM | #9 |
60-66 Nut
We're running the NX288HR. I'm thinking it should run pretty good.
09-21-2009, 03:14 PM | #10 |
OK 2 buttons listed in book,under those years,1 is .642 in and I think thats the diameter,length measures about 9/16 of a inch,the other is .925 round and length is the same I think.The .642 is the one I used with the cloyes timing chain,and the washers are about 1/8.Ok comps book says your button is.795 in length,is that with or without the washer?Mine is max maybe 11/16 all together.
Built chevy tuff! Last edited by Rodms; 09-21-2009 at 03:28 PM. Reason: add |
09-21-2009, 09:35 PM | #11 |
At the body shop.
09-21-2009, 11:35 PM | #12 | ||
60-66 Nut
I really want to build a 406 some day......been wanting to for about 25 years For now I can get my fix helping my son with his
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-21-2009 at 11:36 PM. |
09-21-2009, 11:45 PM | #13 |
At the body shop.
Nope all motor drove it to the track 45 miles one way that combo is two years old with 100plus runs and a ton street time
09-23-2009, 01:29 PM | #14 |
The washer goes on the cover,the button runs against washer OK.
Built chevy tuff! |
09-23-2009, 11:01 PM | #15 |
60-66 Nut
That's what I thought, but I just wanted to make sure. Thanks.
09-24-2009, 12:52 AM | #16 |
don't burn a hole in it,where the x cross on the stock cover thats where it goes,if it starts walking thats what a hammer is for.You should'nt have a problem.You do want the washer tight against the button if you tap it with whatever should not sound hollow!
Built chevy tuff! |
09-24-2009, 11:11 PM | #17 |
60-66 Nut
My son received the new roller cam button yesterday. We'll be using the Milodon reinforced timing cover that we currently have. Sunday is the scheduled day to work on the engine again. I'll let you know how everything works out. Thanks for the help.
09-25-2009, 03:26 AM | #18 |
We don;t have any of the high tech parts but we make stuff work,as long as the cam don't walk out you should be OK.You should be able to tell when you put the cover on.
Built chevy tuff! |
09-26-2009, 10:36 PM | #19 |
At the body shop.
Capt. fab Ive got this water by pass on my 406 and it runs 165/180 degrees all day with a electric fan in 100plus days got it from jegs
09-26-2009, 11:45 PM | #20 |
60-66 Nut
Do you have that plumbed into the rear water ports in the intake at the heads? We haven't had any cooling problems with the SB 400 yet, but we've been running an engine oil cooler too. I'm thinking that must help to some extent. The first one my son had was in a '79 GMC K15, and it came with an engine oil cooler from the factory. That one didn't have any cooling problem, so we've just kept an engine oil cooler on it
09-27-2009, 12:53 PM | #21 |
At the body shop.
Yes plumbed into the rear water ports on the intake. I dont have a oil cooler tho, but the oil pan holds 9 qts also,10 with the tall filter
09-27-2009, 11:50 PM | #22 |
60-66 Nut
Well we finally got the cam end play set today with the shorter Cloyes thrust button. My son got to the shop early and had been working with it for 3 hours when I got there. He ended up welding the supplied washer onto the back of the thrust button for two reasons. 1) the button didn't seem to want to stay straight when sitting in the cam gear and 2) there was very little clearance between the cam gear bolts and the washer if it were to be tacked to the timing cover. I finally suggested fabbing a plate to bolt onto the back of the water pump (long pump) so that we could put tension on the timing cover. That did the trick and we got it set at .0065. We should be able to get this engine in the car and fired up by next weekend.
