Old 09-20-2009, 11:10 AM   #1
nomad0231
Choke? What is this in the pic?!
Ok. So, I know very little about engines, but am trying to learn! Yesterday, me and a friend put on some ceramic coated long tube headers ($186 from Summit!!) Anyways, I noticed this linkage, its in the pic. I can pull on it a little bit. What is this??!? I have trouble with starting when cold, takes a long time to get it to turn over. I bought an Edelbrock 60 w/ elec choke from a board member and hope it fixes the start problem. BUT WHAT IS THIS THING?!?!
nomad0231 is offline   Reply With Quote
Old 09-20-2009, 11:12 AM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Choke? What is this in the pic?!
Looks like the kickdown for an auto trans.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-20-2009, 11:33 AM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Transmission kick down cable, it hooks up on the drivers side of the carb.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-20-2009, 11:36 AM   #4
haminator
haminator's Avatar
It is the kick down cable from your T-350 transmission. It originally hooked to your caeb linkage and the slotted portion bolted to a bracket that bolted to your intake. You could adjust it to where the trans would down shift when you stepped on the throttle. You can still adjust it now, just pull it out a little and put a wire tie or something to hold it in place. It should be pulled out some anyway, it provides extra pressure to the clutch packs. If pulled out all of the way it may not shift into 3rd until 40-50 mph or so.
haminator is offline   Reply With Quote
Old 09-20-2009, 11:47 AM   #5
nomad0231
Wow! You all are truly great! That makes sense! Last night I was driving it and it seemed liked it took FOREVER to shift!! So, the orignal tranny was replaced with a 700R4. (I think) Anyhow, so I put this on the drivers side of the carb, where??? Thanks again everyone!!!
Old 09-20-2009, 12:21 PM   #6
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
If it is the trans cable for a 700R4 then it is not just a kick-down cable, it is THE cable that controls the whole transmission and how and when it shifts. Not having it hooked up or adjusted right will seriously shorten the life of the transmission!!
If you don't know which transmission it is, go under the truck and loock at the oil pan on the transmission. The 350 trans. has a square oil pan with a corner angled off, while the 700R4 has a funky shaped pan. If its been working for a while you probably got a 350, but you better double check and look at the pan.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 09-20-2009, 12:46 PM   #7
fixit-p
fixit-p's Avatar
If it is the TV cable it needs to be properly adjusted here's a link
http://www.tciauto.com/Products/Inst...ble_adjust.htm
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 09-20-2009, 12:49 PM   #8
nomad0231
Ok, just looked. It is square with a corner angled off. I could've swore the "engine guy" who just rebuilt the 350 and the tranny told me it was a 700r4. So what should I do with this cable? I don't want to just leave it dangling.
Also, I looked at the carb and noticed the engine guy put a sizp tie around a floaty looking thing (like that term?!?)
Old 09-20-2009, 01:44 PM   #9
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
this may help
powerdriver 1958 is offline   Reply With Quote
Old 09-20-2009, 02:00 PM   #10
oldgold70c10
Who's got steelies?
You should have a bracket on the intake manifold on the driver's side of the engine. There should also be a place on the carb to clip the cable, or a hole where a stud screws in to clip it on.
Here are some picks:
My Truck Page
My Youtube Channel
Old 09-21-2009, 09:23 PM   #11
nomad0231
That picture was SO helpful! THANK YOU! This is why i'm so glad I bought a '67, I knew there would be outstanding support from this community!!
How much should this be pulled out? I pushed it in some, but it still doesn't shift to 3rd until about 35, seems late doesn't it?
Old 09-22-2009, 10:50 PM   #12
425HP409
425hp409
425HP409's Avatar
Smile Re: Choke? What is this in the pic?!
To adjust the detent cable for your TH350 transmission, with the throttle wide open, pull the cable all the way out and connect it in that position. Your transmission then will have proper pressure and should have detent, or passing gear when throttle is depressed to the floor. The transmission also has a vacuum line from the intake manifold to the vacuum modulator that controls the speed when it upshifts and the relative firmness of the shift. The vacuum line from the modulator must be connected to manifold vacuum (full vacuum at idle). If the transmssion shifts too late or soon, the vacuum modulator may be bad. If trans fluid is present where the vacuum hose connects to it, it is bad. Unless you have an original large diameter vacuum modulator, it is adjustable to fine tune the shifts. To adjust the shifts, remove the vacuum hose from the modulator, with a small screwdriver, turn the screw inside the vacuum port. To raise the points and firmness, turn the screw in (clockwise). To lower and soften the shifts, turn the screw out (counterclockwise). Test drive after each adjustment. I would do a half turn at a time until you have it where you want it.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 09-22-2009, 11:01 PM   #13
highperf4x4
Will this also apply to a th400? Mine is a little soft on the 1-2 shift but firm on the 2-3 shift. I would like it to stretch a little more between shifts too.
I don't have a kick down cable though. Just a switch mounted beside the gas pedal.
highperf4x4 is offline   Reply With Quote
Old 09-23-2009, 09:46 AM   #14
425HP409
425hp409
425HP409's Avatar
On a TH400 transmission, there is no cable. The TH400 uses an electric kickdown, hence the switch on the gas pedal and a wire running down to the left side of the transmission. The vacuum modulator is responsible for upshift timing and feel, and part throttle downshifts, whereas the electric solenoid is responsible for full throttle downshifts. the modulator can be adjusted just like one on a TH 350. If adjusting it doesn't do what you want, you may have to have a transmission shop look at it for a repair or adjustment in the valve body or servo.
Charles
90 ZR1 Corvette
Old 09-23-2009, 02:41 PM   #15
highperf4x4
Ok, thx
Old 11-05-2009, 12:54 AM   #16
Razr
can some plz post a pic of the switch on the gas pedal for the TH 400 transmission.Where is the electric switch located.......
Razr is offline   Reply With Quote
Old 11-05-2009, 01:39 AM   #17
highperf4x4
I broke my camera last week but I'll see if my phone can take a good enough pic tomorrow.
Old 11-05-2009, 02:29 AM   #18
Razr
thanx
Old 11-05-2009, 12:15 PM   #19
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
"can some plz post a pic of the switch on the gas pedal for the TH 400 transmission.Where is the electric switch located....... "
This is the setup on my 67, 327 4jet TH400.....Hope it helps
screamin_c10 is offline   Reply With Quote
Old 11-05-2009, 12:30 PM   #20
Mertz
If I set mine up with the throttle wide open it wants to shift down at odd times. If I pull on the cable it moves all the way out but then if I pull a little harder it move another 1/4" or so. Do I set it so I have it completely out or just before the extra movement. BTW my 350 was just rebuilt so eveything should be working correctly. I just switched from and Edelbrock to a Q-jet so the length of the linkage to the carb is different. It had a small extention on the linkage to make it work for the Edelbrock but it is to tight if I hook it up directly to the Q-jet.
Mertz is offline   Reply With Quote
Old 11-05-2009, 01:56 PM   #21
Razr
here is how mine is setup can someone plz help identify switch
Old 11-05-2009, 02:06 PM   #22
71swb4x4
71swb4x4's Avatar
No switch that I can see in those pictures. If you have a TH400 the switch should be on the gas pedal.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-05-2009, 02:07 PM   #23
Sinister
Between Trucks...
Sinister's Avatar
Some had the switch at the carb.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-05-2009, 02:32 PM   #24
fixit-p
fixit-p's Avatar
it's the switch with the orange and yellow wire in screamin's post. That sw wont work on an Edelbrock carb you can use a Lokar kick down switch or a nitrous wide open throttle switch.
http://www.summitracing.com/parts/LOK-KD2400HT/
http://www.summitracing.com/parts/EDL-72280
Old 11-05-2009, 04:19 PM   #25
jd4300fel
jd4300fel's Avatar
does anyone happen to know where this connects to on the tranny ? I was under the impression that the 400 only used vacum.
Mike K
Friend of Bill W
jd4300fel is offline   Reply With Quote
