Old 09-20-2009, 01:13 PM   #1
Metz
ps and fuel ?
I need to find out what ps brackets are needed for a 77 350 that will have ac and what diameter 2 groove pulley is needed. The fuel ? is my 77 has two ports and the 79 truck has a return line. Do I needto change pumps or can I just plug the return line? Thank you in advance.
Metz is offline   Reply With Quote
Old 09-21-2009, 10:44 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: ps and fuel ?
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-21-2009, 12:57 PM   #3
menace121978
menace121978's Avatar
Re: ps and fuel ?
alright buddy, i'll give this a shot. for the pulley i took a few pics for ya. mine was a factory a/c truck that i took the compressor off of but left the brackets. the pulley on the p/s pump is 1 1/4 thick and 5 3/4" in diameter. heres the pics of the brackets.
now for the fuel... on the tank the ports are a sending unit. there isnt a pump in there unless its been switched to an electric pump. the should be only 2 ports, 1 for fuel feed that goes to the fuel pump on the engine block and the other goes to a charcoal canister mounted under the hood on the driver side fender or core support. heres a couple pics of mine...
vent line...
now if your new motor has a manuel fuel pump which it should then you can plug off the 3rd port. hope this makes sense and helps. Dennis
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-21-2009, 07:17 PM   #4
Metz
Re: ps and fuel ?
Thank you Now I need to make the header bracket and I should be good. My 73 onlly has a vapor return but the 79 has a wet return lineas well as a vapor line. Does anybody know where to locate ps brackets for ac a setup? Thank you
Old 09-22-2009, 02:37 PM   #5
Metz
Re: ps and fuel ?
I have the wrong ps backet and pulley. I will s have to locate the right one. Thanks again
