Old 09-20-2009, 04:07 PM   #1
Rat72
Rat72's Avatar
ECE Hidden Hitch on 4WD
Has anyone mounted an ECE Hidden Hitch onto a 4WD truck? The leaf spring mounting bracket has a support on it that bolts to the bottom of the frame and to the side of the leaf bracket. I could cut out some of the hitch but I don't like the idea of reducing the number of bolts on the hitch. I could remove the support but I assume the support is there for a reason. Or I can make a new support bracket. Are there any other solutions that don't require bracket fabrication and don't decrease the integritty of the hitch or the spring mount?
Rat72 is offline   Reply With Quote
