09-20-2009, 05:15 PM | #1 |
Longtime Member
Anyone running a 6spd Manual?
I'm starting to plan my '72 short step build (starting sometime in the spring) and it's looking more and more like I will do an LS swap. Also, I want a manual...anyone here running a T56 or something similar or should I stick to a truck 5spd?
For those of you that are running a 6spd (if there are any) what shifter set up are you using?
Rokcrln - "I'm a major car addict so trying to go as low buck as possible is like asking a coke head to use flower to save money." 1972 C10 Short Step -http://67-72chevytrucks.com/vboard/s...d.php?t=261405 |
09-21-2009, 12:11 AM | #2 |
Longtime Member
Re: Anyone running a 6spd Manual?
no one?
09-21-2009, 06:32 AM | #3 |
I'm not right now, but I've got a PT/handling truck rollin' around in my head that has one behind a 6.0 LS. I say go for it!
09-21-2009, 10:13 AM | #4 |
motor exploder
I don't have an LS motor, but I am running a TREMEC TKO 5spd. I'm using a McLeod hydraulic throwout bearing and the TREMEC shifter with a Hurst stick for a bench seat car.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
09-21-2009, 10:19 AM | #5 | |
Longtime Member
Then you, sir, have read my mind 'cause that's exactly what I'm shooting for with my build! A corner carving street fighter with a 6.0 and a 6spd that isn't afraid to go pick up some weekend landscaping supplies.
09-21-2009, 10:22 AM | #6 |
newly minted old timer
i think that setup would be the absolute best set up for our trucks.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
09-21-2009, 10:39 AM | #7 |
If I were to put a manual behind a LS engine, i'd definatly stick with a t-56. If you put a t-5 behind it, it will be toast very shortly and the other 5 speeds that may handle the power would probably be more expensive than the t-56.
Also, make sure you get an LS1 t-56. The LT1 t-56s have a goofy clutch setup. As far as the shifter goes, I know the "Pro 5.0" shifter I had in my '01 formula had a removable handle, so you could just make a different length handle more suitable for a truck and bolt it to the base. |
