Frame swap
picked up a 1964 c-20 pick up with a 230 6 cyl 3 spd .i want to lower the suspension i read on this site about the dropmember and z-ing the frame. then my brother gave me a 1988 c-1500 pick up in rough shape .i pulled the cab and bed off and i am going to use the chassis from the 1988. i am going to channel the cab because the floor and cab mounts are rusted out.the front i guess dropped spindles and air bags will get it down. what could i replace the leafs in the rear ? here are some pictures of the truck and current project.
![]() Join Date: Sep 2006
Re: Frame swap
Pics? Don't see any....
![]() Need to check with your local DMV to see how you will need to register your truck. Here in Nevada its the frame they check, and anyting 67 and older is smog exempt which is a real bonus, especially when modifying. Its too bad it is not an 87 or older as most of the running gear is an easy swap. But hey you got to go with what you got. Throw up thempics so we can check it out. ![]() |
we tried to post tht pictures could not figure it out. apperciate any help thanks
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Frame swap
Since you're not a paid member, you will have to upload them to a hosting site such as Photobucket, or Imageshack, and then enter the url of the pic when you click the insert image icon above the text box.
#5 | |
and a few others
Re: Frame swap
When you click the "reply to thread" you'll see at the top of the text box, a little paper clip. Click on that and choose the pics you want to attach. You may have to re-size your pics depending on how big the ones you have on your computer are. I usually have to re-size them to 50%. Hope that helps. And, welcome aboard. Always nice to have another 60-66 guy !
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Re: Frame swap/Photos
Trying to upload photos I get this error message any help?
"Your submission could not be processed because a security token was missing." |
Re: Frame swap
Here are some pics, finally!
Re: Frame swap
the pictures of the truck is my next project. the picture of the car is a project i am trying to finish. you can never have enough projects.
#9 | |
60-66 Nut
Re: Frame swap
Sorry for the incorrect information. I thought that was one of the perks of a paid membership
![]() Quote:
Re: Frame swap
no problem
Re: Frame swap
why would you even tell them?? this is done all the time. if you get pulled they check the vin on the dash if anything
Re: Frame swap
#13 |
Re: Frame swap
[URL=http://img696.imageshack.us/i/008qz.jpg/][IMG=http://img696.imageshack.us/
#14 |
Re: Frame swap
I started working on this project again its getting cold outside so i put the truck inside the garage. i have pictures i am trying to rember how to post them on again
#15 |
Re: Frame swap
more pics please!
I was just wonderin' yesterday how hard it would be to swap a '64-'66 body onto a '88-'95 frame and running gear. I was thinking 4x4 though. |
#16 |
Re: Frame swap
