Old 09-20-2009, 08:42 PM   #1
pepe_38
64 chevrolet truck
i got this truck is seat on blazer frame i like to swap to a diferent frame any good sugestions thanks
pepe_38 is offline   Reply With Quote
Old 09-20-2009, 08:58 PM   #2
198plus
198plus's Avatar
Re: 64 chevrolet truck
Yea ........ since you live in Ga. I've got a 65 frame for you ????
198plus is offline   Reply With Quote
Old 09-21-2009, 04:22 PM   #3
pepe_38
well i like to keep on 5 bolt pattern how much you take for you frame and wat comes w/ the frame thanks
Old 09-22-2009, 12:47 AM   #4
Captainfab
60-66 Nut
So that Blazer frame is a 2wd correct?
Old 09-22-2009, 03:44 PM   #5
pepe_38
yes 2 wheel drive but i don like ride that high
Old 09-23-2009, 12:07 AM   #6
Captainfab
60-66 Nut
Yes that is how these trucks end up when put the body on a '73-'87 2wd frame, unless the body is channeled. Which is a lot of work.
If you can get that frame from 198Plus. Then put the front suspension and rear differential on that new frame. That way you'll have the correct style frame with a good ride height and your 5 lug wheel bolt pattern. It'll be some work, but well worth it in the end.
Old 09-23-2009, 03:58 PM   #7
pepe_38
thanks
