Old 09-21-2009, 09:14 AM   #1
snj8198
snj8198's Avatar
DIY4X disc brake brackets
hi guys. its time to up grade my brake system so i figure a good start would be a rear disk conversion on my FF14bolt. I have been looking at various brakets on the market and seem to keep coming back to DIY4x products. anybody care to post opinions on who and what or throw me some suggestions. also on the table will be the need for a new brake booster and mc. I am currently searching the site for this info and i assume i will need to start a new post for that. i would like a small diameter one ton booster so i can pull the driver's side valve cover without having to remove the booster from the firewall. suggestions??
thanks for your time. -steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 09-21-2009, 02:53 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: DIY4X disc brake brackets
The brackets from Ruff Stuff Specialties are the only ones I will buy they are only $60 shiped to your door and they are bent so there is no need for spacers to make them line up correctly.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 09-21-2009, 03:09 PM   #3
Storm Chaser
Storm Chaser's Avatar
I haven't bought those brackets (yet) but I have bought other stuff from DIY, and all I can say is their stuff is top quality and their customer service is excellent. I usually look to them first.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 09-21-2009, 03:46 PM   #4
snj8198
snj8198's Avatar
i gather the bent tabs are for the calipers to line up correctly with the rotors? other wise the bracket needs to be shimmed?? this must be why i see some brackets with the additional round ring included or shims machined onto the bracket around every mounting hole i guess.
i've heard a lot of good things about DIY4X's products which lead me to consider them.
have you guys found any pros or cons to running either the bent brackets versus brackets using spacers?
Steve
Old 09-21-2009, 05:22 PM   #5
royo
royo's Avatar
Heres kerts# at 712-479-2251# call him if you need to know about his brake stuff
nickle and dime
royo is offline   Reply With Quote
Old 09-21-2009, 05:26 PM   #6
snj8198
snj8198's Avatar
thank you sir
Steve
Old 09-21-2009, 06:14 PM   #7
84 400
Sb 400 club
84 400's Avatar
yeah he has great customer servace and top quality beef stuff. Never bought the brake brackets but i would buy from DIY any time
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 10-06-2009, 08:57 PM   #8
66Z71
66Z71's Avatar
I have a set of the DIY4X brackets here for my project, along with some of their spring mounts. Top quality stuff. I have made brackets like those to put disk brakes on my Corvair, they cost more to make and werent any better looking.
66Z71 is offline   Reply With Quote
Old 10-12-2009, 03:09 PM   #9
msgross
msgross's Avatar
check the parts board for a nice MC/Booster setup... pickmup has some great deals...
http://www.67-72chevytrucks.com/vboa...d.php?t=363832
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-12-2009, 05:37 PM   #10
snj8198
snj8198's Avatar
I've heard a lot of great talk about DIY's products and will probably go this route very soon. I would like to purchase their FGB52 kit also but am unsure if i want the truck sitn that high. I clear my 35's fine but don't stop them very well.
that's a great looking set up msgross! I'm unsure if i want to do a small diameter booster system like his 9" or dive into a hydroboost system. just another project im on the fence with. I should start a new thread and call it Steve's on the fence. Then next year after weighing the pro's and con's i could maybe start my project. Or not, im unsure.
Steve
Old 10-12-2009, 06:18 PM   #11
msgross
msgross's Avatar
or you could be like some of us and buy both setups, then decide on a third later!
The Garage:
