Engine Swap - truck will not shut off
so i just finished up my first ever engine swap yesterday and started it for the first time!! very exciting - everything went well - except i went to shut the truck off and nothing happened it kept running...
the switch worked fine before - it still could be bad i know! - but im wondering if it is related to my alternator upgrade. i switched to an internally regulated one from a newer truck and got the kit from lmc to connect it. it was just a 4 inch cable with the 2 correct plastic plugs to switch it - and a terminator block for the connection to the old regulator. anyone else seen this problem? or probably just bad switch? BEFORE ![]() AFTER ![]()
1967 K20 'the white truck' sm420/Rockwell t221 Dana 44 front w/ Dana Spicer 1/4 turn lockouts Eaton Ho52 rear "holy **** this thing is a tank!" As soon as your born you start dying so you might as well have a good time! |
