09-21-2009, 11:51 AM | #1 |
How do you install new hood hinge springs?
What's the best was to do this without killer yourself or more importantly not sctraching new paint and powder coat?
09-21-2009, 05:28 PM | #2 |
1961 crewcab
Re: How do you install new hood hinge springs?
Cover the area with masking tape to prevent scratches,then peel it out before the bolts are tightened up.
I cant remember which bolt is first-maybe someone else will chime in- but you snug one, and the let the hinge rock forward and back around the other, and that gives you enough room to get the spring on. |
09-21-2009, 09:11 PM | #3 |
Senior Car Nut
my son-in-law showed me a trick a couple of months ago and I've since used it twice to install (and once to remove) these hood springs and again on the tension spring on a mower. Install the hinge and move it to the full up position, get some small (1/4 inch diameter) rope (like clothes-line) and tie it to one end of the spring. Put the back end of the spring in its slot and, standing in front, pull on the rope. If you do it just right the spring pops into place.
Larry |
09-21-2009, 09:38 PM | #4 |
There's another thread somewhere about this. I haven't tried it but you basically stretch the spring with your floor jack and put spacers (big washers or whatever you have around the shop) between each coil. Then let the jack down and the spring will be spaced out longer. You will have to play with the number of spacers to get it to a point where you can get it on the hinge with the hood full open. Then carefully lower the hood and take the spacers out.
09-21-2009, 09:38 PM | #5 |
Just here to tinker
A pair of vise-grips, two beers and a first aid kit.....
No seriously though, what was mentioned above is a good and safe way, always be careful though...
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
09-21-2009, 11:11 PM | #6 |
Member of the longbed union.
Corts you forgot the duct tape and bailing wire.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
09-21-2009, 11:33 PM | #7 |
i have used the rope technique . I had my nighbor "tap" it with a hammer to help seat it
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
09-25-2009, 06:31 PM | #8 | |
Its Deja Vu time again
