Old 09-21-2009, 02:29 PM   #1
shrtbx
whats up with my F#$#@ fuel gauge
I know these trucks dont have the best fuel gauges but im confused. It always seemed to work when it wanted to. As time went on it would be all over the place. Now it just sits all the way past E. I picked up another gauge but is it something other than the gauge?
shrtbx is offline   Reply With Quote
Old 09-21-2009, 03:13 PM   #2
lowrod65
lowrod65's Avatar
Re: whats up with my F#$#@ fuel gauge
man im having the same problem with my 82, so i hope someone has a fix.
kill'em all
lowrod65 is offline   Reply With Quote
Old 09-21-2009, 04:01 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
its prolly the wire ontop of the sender on the tank you can usually get to the brown wie betweeen the bed and cab just try to jiggle it ans see if the contact is bad
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-21-2009, 05:15 PM   #4
diamondave
Same problem with my 79... I kicked the tank and it works now... when I have time I will properly check it...
Static Dropped 1988 Chevrolet ECLB
"Hovering less then 3 inches from the ground... full-time"
diamondave is offline   Reply With Quote
Old 09-21-2009, 05:59 PM   #5
78maliburat
if its past E its most likely a ground issue
78maliburat is offline   Reply With Quote
Old 09-21-2009, 06:31 PM   #6
Storm Chaser
Storm Chaser's Avatar
I agree with the bad ground- from the sender to the frame
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 09-21-2009, 08:21 PM   #7
lowrod65
lowrod65's Avatar
ok heres my problem. when the key is off it shows half full, when i turn the key on it goes past full. any ideas?????
kill'em all
Old 09-21-2009, 09:38 PM   #8
old Rusty C10
on these trucks 99 / 100 times its the wiring ontop of the tank start there and work backwards
Bob
I hate cancer!!
Old 09-21-2009, 09:40 PM   #9
78maliburat
most likely ground also
Old 09-21-2009, 10:48 PM   #10
asphaltburner
asphaltburner's Avatar
Yo! If the fuel needle is pegged beyong full, you have an open within the circuit. Either a break in the grounding to the truck frame (most common), or a break in the positive electrical supply to the sender. The fuel gauge is supplied with 12v+, a ground, and a lead to the sender. The sender has a lead from the gauge and a grounding lead. Grounds are a problem in this circuit, usually due to corrosion, or road damage. The sender lead can be damaged, or the plugin near the starter can corrode. This may help you track down the open.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 09-21-2009, 11:04 PM   #11
lowrod65
lowrod65's Avatar
well im off tomorrow so first thing in the morning i will check everything out starting at the tank. thanks for everybodys help.
kill'em all
Old 09-21-2009, 11:23 PM   #12
shrtbx
Let me know how it goes. As soon as i get some time again im going to check out the wires as well.
Old 09-21-2009, 11:32 PM   #13
lowrod65
lowrod65's Avatar
yeah as soon as i get it figured out i'll post wat the problem actually was and how it was fixed.
kill'em all
