Emissions fail - any advice
I've failed emissions twice on my '71 C20 5.7L.
Prior to first test: Vehicle was not running when I bought it. Fresh oil/filter, new plug wires, new gas tank, flushed fuel lines, new carburetor, timing adjusted, idle screw adjusted but left idle fuel mixture screws alone (new Edelbrock carb, thought it would be dialed in). Pollutant: Reading/Standard - Result Loaded Hydrocarbons (HC) in PPM: 132/450 - PASS Loaded Carbon Monoxide (CO) in %: 3.54/3.75 - PASS Idle Hydrocarbons (HC) in PPM: 379/450 - PASS Idle Carbon Monoxide (CO) in %: 8.94/5.0 - FAIL Prior to second test: Idle fuel mixture screws dialed down as low as possible without stalling, Idle set precisely 550RPM in drive, replaced PCV valve, new spark plugs, burned one can of "guaranteed to pass" emissions formula, filled up with 91 octane, added 1 can of octane booster, drove for about 20 minutes on the freeway to get it hot as hell prior to testing. Pollutant: Reading/Standard - Result Loaded Hydrocarbons (HC) in PPM: 149/450 - PASS Loaded Carbon Monoxide (CO) in %: 5.68/3.75 - FAIL Idle Hydrocarbons (HC) in PPM: 119/450 - PASS Idle Carbon Monoxide (CO) in %: 1.88/5.0 - PASS I'm going to give this one last try prior to taking it to a shop. I may have screwed up the "guaranteed to pass" emissions formula by not running the tank completely empty (looked empty but when I filled up it only took 15G). I'm going to run it empty again and put more fresh high octane. I also plan on changing the oil again, the engine was likely all sludgey after sitting for 4 years and 2 oil changes won't hurt. I'd really appreciate any suggestions because I'm out of ideas. I've already spent a small fortune on this thing and can't get it licensed. I really don't need to start dealing with a mechanic on this truck, I bought it so I could do the work myself. Any tips/tricks/repairs before I go again??????? |
Re: Emissions fail - any advice
You went the wrong way. Excessive carbon monoxide indicates a LEAN mixture, not fat. So you were running lean at idle on the first test and OK in the midrange. On the 2nd test, you got the idle mixture right, but something affected the midrange and caused you to run lean under a load.
Excessive Hydrocarbons indicate a fat mixture. Edelbrocks typically run leaner than Holley's from my experience. Richen it up, and possibly jet it up one size if possible and you may pass. Also, try running some marvel mystery oil through the gas and oil per the bottle's recommendations. Not sure if that will work, but if it's been sitting for a while, I think it's supposed to clean things out. Last edited by 69GMCLonghorn; 09-21-2009 at 05:35 PM. |
#3 | |
![]() Join Date: Jan 2001
I've had success in the past running my old carbureted Subaru with denatured alcohol in the tank. I ran it down to about 5 gallons of gas and added a gallon of denatured. I had to boost up the idle speed a little bit to get it to idle smoothly. The tech at the I/M station said, "I don't know what you did, but you sure cleaned this thing up."
#5 | |
What?
Wow, AZ requires you to smog your 1971 truck. I had to look it up, and sure enough you guys have to smog everything from 1967 on up.
Here in CA where I thought just about every law was out of whack, CA exempts everything pre 1975 huh. If I were you, and others will prolly scoff at this. But I'd find a good 1971 Q-jet and temporarily swap out the Edlebrock, since IIRC those carbs aren't smog legal anyway. So you may be wasting your time? I'd dunno, just throwin it out there.
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 09-21-2009 at 06:02 PM. |
Moderator
![]() Join Date: May 2007
Try running 87 octane fuel instead. When I had to take emissions tests in the past this helped. I have had several smog techs tell me this too.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#8 | |
Moderator
When CA still required smog checks on my 67 Camaro, I took it to many smog testers till I found a Korean guy that just passed it, no questions asked even though I had no smog equipment and all aftermarket stuff. I also knew a guy that merely needed the VIN and $200 and could get it passed. My buddy found another smog guy that played his carb until it passed and then put it back to where it would actually run right.
#10 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 09-21-2009 at 06:23 PM. |
What?
I just read one of your other posts, and in it you say you are running headers?
If this is true, here in CA they would fail you on just the visual. If your state allows this, then you need to take into account for those headers while figuring out your A/F settings. In that other post, you also mentioned you are using an HEI with 7mm plug wires that are melting on the headers. Bad ignition will affect your smog test also, since you are probably arching on the header pipes from the melted wires. I'm no expert at emmsions testing, but these I think would be pretty important issues to address.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
member #16
![]() Join Date: Dec 1999
Back when mine was still under smog rules I had them check the emissions before the test, Then if an adjustnent was needed it was done before the actual test.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#13 | |
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#14 |
Lean mixture will lower CO. not the other way around.
The mixture screws on an edlebrock only change the idle mixture. The difference between the two under load measurments would indicate a testing error (assuming that nothing else changed). Grounded spark causing a miss will lift the hydrocarbon count. I don't think that is it. Bring your idle mix up a little. Get your idle around 850. Test again. In Colorado, the retests are free. Once I told the guy to retest three times in a row. It passed on the third without any adjustments. I think that the test probe is not the most accurate.
__________________________________________ Sean 1972 C20 2005 4Runner ![]() |
#15 |
The good ol days.
#16 |
Eat My Rust
Move to Texas. As long as your lights all flash and your horn goes beep, it passes.
#17 |
#18 | |
Sierra Grande Club
![]() s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#19 |
you need to move to Indiana... no inspections at all!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#20 |
Alright Alright Alright
Yeah, in Texas, it 14.00 dollars (blinkers, horn, tail lights, and wipers all work) and youre on your way. Its a restorers dream.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
#21 |
Eat My Rust
And you have to have muffled tail pipes 'past the doors' is the basic rule of thumb, but if you find a cool shop they can even let that slide I'd wager.
#22 |
NO OCTANE boost or high octane gas.....that screwed ya right there.... OCTANE SLOWS THE BURN !!!... anyways get a can of acetone, dump in gas tank, set mixture screws correctly (turn in till stumbles/idles rough then turn out 1/2-1 turn) set idle at 1000-1500rpm.... make sure its at operating temp when ya get there and dont idle in line.... (ex phoenix resident just went thru getting my 91 to pass)
#23 |
![]() Join Date: Sep 2005
IN GREAT OLD NC any vehicle 35 years or older does not have to pass any kind fo inspection
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#24 | |
I have been going to the same place and many people for years! |
#25 |
Hollister Road Co.
