09-21-2009, 11:22 PM | #1 |
profeshinaly unimployed
alot of brake questions
ok i have a 1982 k10 with a 400sbc and manual hubs
i need to replace the brakes on the front right side and the rotor on the front right side...now ive ben told that you have too replace the hub with the rotor...is that true cuz i found just the disc for sale at advancehere and also does anyone have a right up anywhere that i can read through on this process cuz i plan on replacing the rotor in the next couple days and i have no clue were to start do to it being a 4x4 and all so can i get some help from some of the wonderful people on this wonderful forum
"having mud flaps is like asking for a smaller trophy" |
09-22-2009, 01:16 AM | #2 |
Gettin It One Pice At A Time
Re: alot of brake questions
I dont know about the hub question. but one thing I have always been told when it comes to brakes is to replace pairs. front or back, never one wheel. as it can be very dangerous. but open to be corrected.....
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
09-22-2009, 01:32 AM | #3 |
Yo! Hub too? Geeze! BS,...rotor replacement should be easily done with the same hub, unless there is something wrong with it. Replace bearings (if needed at this point) and seals at the same time,...and I agree,...do both sides at the same time, front or rear.
Best and cheapest would be repack bearings both sides, brake pads both sides, replace that rotor, and new seals both sides. Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
09-22-2009, 02:04 AM | #4 | |
09-22-2009, 04:02 PM | #5 |
you can buy the rotor with or without the hub installed.it will be cheaper to just replace the rotor.as far as the locking hub you will need to replace it as the threaded hole is probably cracked and is not repairable(from past experience)if your talking about the allen head ones that hold the outer cover on.
09-23-2009, 11:20 PM | #6 |
so does anyone know of a good right up
09-23-2009, 11:54 PM | #7 |
Yo! See the above,...it includes what to do with the hub that has a stripped bolt and I've listed what you need. Just clean and repack your bearings if they are shiny. Forum search may give you a full blown procedure for this task,...or Haynes' or Chiltons' manuals.
Todd.
09-24-2009, 04:31 PM | #8 |
well i got the rotor the grease and the brake pads looks like ive just gotta read up hot to do it a before more then give it a shot
09-24-2009, 04:40 PM | #9 |
well i used the search function and still cant find a how to i cant even find one on google
09-25-2009, 04:23 PM | #10 |
is there not one person in this whole world who can tell me how to take my hub off ive ben sitten here for 3 hours searchin all kinds of things trying to find out how to take off my hub and rotor and no one on this earth can help me so can some one please just give me some details on how the heck im supose to take off my darn hub
09-25-2009, 08:27 PM | #11 |
Happy to be here
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-25-2009 at 08:29 PM. |
09-25-2009, 08:44 PM | #12 | |
I wish I were closer, I would try to teach you something
CHEVY ONLY Last edited by joe231; 09-25-2009 at 08:48 PM. |
09-25-2009, 08:45 PM | #13 |
The hub and rotor are one piece. They sell for about 30 bucks a piece. First you pop off the dust cap. Then remover the cotter pin and nut.Then you pull the rotor and bearings. You need to the pull out the inner bearing and seal and transfer them to the new rotor. Then You put them back. Need anymore help ask. I just did my entire front as well as my buddy's chevy astro van. The new wheel seals are only 3 bucks each for the two.
____________________________________ |
09-25-2009, 08:47 PM | #14 |
Poke's is 4X4
totally different hub
CHEVY ONLY |
09-25-2009, 08:49 PM | #15 |
Damn. Didn't notice that. Best bet would be to go to the local parts store and browse through the Haynes manual.
09-25-2009, 10:34 PM | #16 |
Kid's Mechanic
forgot which you have but 1st is manual hubs and the 2cd is auto hubs;
This procedure requires snap ring pliers and a special hub nut wrench. It is not very easy without them. 1. Raise and support the front end on jack stands. 2. Remove the wheels. 3. Lock the hubs. Remove the outer retaining plate Allen head bolts and take off the plate, O-ring, and knob. Take out the large snap ring inside the hub and remove the outer clutch retaining ring and actuating cam body. This is a lot easier with snap ring pliers. Relieve pressure on the axle shaft snap ring and remove it. Take out the axle shaft sleeve and clutch ring assembly and the inner clutch ring and bushing assembly. Remove the spring and retainer plate. 4. Remove the wheel bearing outer lock nut, lock ring, and wheel bearing inner adjusting nut. A special wrench is required. 5. Remove the brake disc assembly and outer wheel bearing. Last edited by powerdriver 1958; 09-25-2009 at 10:56 PM. |
09-25-2009, 10:55 PM | #17 |
Kid's Mechanic
Just another thought,If the pads are burnt up on one side only you may have a caliper stuck or a bad brake hose
