Old 09-22-2009, 06:29 AM   #1
brn agn
brn agn's Avatar
Difference in lower control arm shaft?
My Dad and I are in the process of putting a disc brake conversion kit on my 69 SWB. During the disassembly process, we discovered that that lower and upper control arm bushings were worn.
We found the replacement shaft kits and when my Dad was putting it all back together, he found that the dimples in the new shafts are about 3/8" further from the end compared with the stock shafts.
If we used these shafts, it would push the lower a-arm forward, which would dial in more caster. I have included pictures below. Does anyone have any experience with this? Are the parts wrong or was there a change to the design of the part over the years? We are taking the parts back to the store tomorrow to see if they can help, but I knew there was a wealth of knowledge on here. Any help would be appreciated.
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 09-22-2009, 09:28 PM   #2
texastrendz
Re: Difference in lower control arm shaft?
i dont know what brand you got, the only shaft that i found that would not bind up once i got it installed was the moog brand, moog in my opinion is simply the best. i tried cheaper versions and the arm would bind up so bad that it would actually back the bushing caps out of the arm. just my 2 cents. and oh yea the dimple was the same as the factory shaft to the moog shaft.
texastrendz is offline   Reply With Quote
