Under construction!
I am using brand-new factory style hardware from LMC Truck for the upper shock mounts. The problem is that the head of the bolt is enlarging the bushing---When I torque the nut from the inside of frame rail. I also placed two lock washers on both sides and it still slipped through. Should I purchase a flat washer that is larger than the bushing and place it between the bushing/head of the bolt? That way, it would apply pressure to the entire bushing, and the bolt would not be able to slip through. Thanks for any suggestions.
2001 Silverado bagged on 22's. *Sold* |
| Bookmarks |
