454 Timing ?
Hey guys I just got my 454 fired up this weekend for my 72 K20 it is bored .40 over, a .510 lift comp cam aluminum intake and 770 holley and its running and 18 degrees retarded just fine and smooth when I turn the distributor to 0 when running it gets real choppy like it should but when I go to give it gas it falls on its face..anybody got any ideas? Thanks
72 K20 Project now! 70 GMC K20 (Farm truck) on 35's 71 Gmc K20 (Parts truck) 72 Blazer (Parts) 74 3/4 ton (Farm truck) on 35's 84 3/4 ton K5 (Mud toy) on 38.5's 86 3/4 ton (puller) on 36's 98 Cummins (Puller) on 305's Last edited by JCaldwell; 09-22-2009 at 09:06 AM. |
Re: 454 Timing ?
1. The balancer spun and the timing mark is off.
2. Are the vacuum lines plugged while setting timing? 3. Timing tab is misaligned. |
Re: 454 Timing ?
well the vacuum lines are plugged but dont know about the other
72 K20 Project now! 70 GMC K20 (Farm truck) on 35's 71 Gmc K20 (Parts truck) 72 Blazer (Parts) 74 3/4 ton (Farm truck) on 35's 84 3/4 ton K5 (Mud toy) on 38.5's 86 3/4 ton (puller) on 36's 98 Cummins (Puller) on 305's |
The Engine Whisperer
Re: 454 Timing ?
were you reusing the old balancer?
If you did, there is a good chance that as mentioned by 71Tahoe that the outer ring of the balancer is spun from where it should be. Last edited by ProStreet68SB; 09-22-2009 at 05:13 PM. |
Re: 454 Timing ?
Yea its the old balancer..could that actually happen? What do you think the timing she be at?
Re: 454 Timing ?
Usually big blocks will run better with a lot of timing. I would try 12 degrees btdc and bump it up if needed.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Re: 454 Timing ?
i'm running 24 degrees btdc on my 396 bored 40 over with comp cam
Re: 454 Timing ?
Oh wow 24 degrees maybe Im rite then..I was figuring about 8 to 10
#9 | |
Re: 454 Timing ?
Are you sure that you are not confusing advanced and retarded? It has happened more than once.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#10 | |
Re: 454 Timing ?
Retarded is BTDC right?
member #16
![]() Join Date: Dec 1999
Re: 454 Timing ?
BTDC is advanced. (before top dead center)
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 09-30-2009 at 05:08 PM. |
Re: 454 Timing ?
Another piece of advice on this....on an engine like that I wouldn't screw around with setting it at base. You need to be timing that thing at full advance. It's hard for me to say how much without knowning a little more details about the engine, most importantly compression ratio.....but assuming it's in the 9.5 - 10:1 range I'd suggest that you start around 32 degrees, and work your way up 2 increments at a time until you find your sweet spot.
Most of my big blocks have always liked about 34-36, but I used to have a 468 that only ran like it should've at 40....so you never know until you mess with it.
72' LWB Cheyenne 73' Camaro Z28/RS 70' Chevelle RagTop 00=ss=00 |
#13 |
Re: 454 Timing ?
wft are you turning the dist to 0?
when the motor is running the the line should run uphill to nearly straight up and down at heavy throttle. i ran my old 454 at 24ish btcd too. as far as the balancer goes, take the retaining bolt off and look at the keyway, it should line up with the timing mark on the outer ring. |
#14 | |
PITbut
Re: 454 Timing ?
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! ![]() My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
#15 |
Re: 454 Timing ?
My 402 likes to be around 16* btdc to run its best.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
