Old 09-22-2009, 09:24 AM   #1
JCaldwell
Radiator hose
I have the 72 with 2in body 454 and aluminum radiator and cant find a decent lower radiator hose for nothing everything either kinks (even with a spring in it) or just dont fit right..a 74 chevy hose bends are perfect but one side is 1.5 the other 1.75 I need 1.75 on both ends..any help?
72 K20 Project now!
70 GMC K20 (Farm truck) on 35's
71 Gmc K20 (Parts truck)
72 Blazer (Parts)
74 3/4 ton (Farm truck) on 35's
84 3/4 ton K5 (Mud toy) on 38.5's
86 3/4 ton (puller) on 36's
98 Cummins (Puller) on 305's
JCaldwell is offline   Reply With Quote
Old 09-22-2009, 09:42 AM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Radiator hose
No insult intended, but have you been trimming the hose to fit? They need to be cut down a little bit.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-22-2009, 10:27 AM   #3
rwolf9653
more ideas than money
rwolf9653's Avatar
Re: Radiator hose
Have you tried the blue hoses? I cant remember but I think that they are goodyear??? I had a similar problem with my jeep and its lower hose, so I got the blue hose and have had it 2 years so far with no problems. I want to say goodyear gator hoses, but I dont think that is right.
edit* The hose is called high miler.
While I was looking for that I found this also.
http://www.coolflex.com/cfm/welcome.cfm
Sounds like that might help also.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 09-22-2009, 04:48 PM   #4
JCaldwell
Re: Radiator hose
Yes I tried trimming them.. I have a flex hose now that worked great until I started it and it got hot then kinked and bent the spring in it
72 K20 Project now!
72 Blazer (Parts)
Old 09-22-2009, 07:47 PM   #5
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Radiator hose
If you have a friendly parts store I always go in the back and find what I need. Bring the 74 hose and a tape measure to find one similar with the right ends. Or shove the 1.5 over the 1.75, I've done that in the past.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 09-22-2009, 11:23 PM   #6
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Radiator hose
I ended up buying two different hoses cutting them roughly in the middle(it just happened that way) and using a piece chrome molly tubing inside to make the splice.
I used a Gates shrink to fit hose clamp which formed a nice clean seamless intersection.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 09-22-2009, 11:38 PM   #7
70cst
70cst's Avatar
Re: Radiator hose
Good idea...I would not have thought of that.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-23-2009, 06:33 AM   #8
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Re: Radiator hose
I had the same problem I bought the 75 bigblock lower hose the bends are perfect and I just lubed the hell out of it till I managed to get the other end on. On the other hand this thought came to mind "take the radiator in and get the lower part where the hose goes changed out and rewelded to the right size nothing a good welder couldn't or wouldn't do...
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 09-23-2009, 12:25 PM   #9
JCaldwell
Re: Radiator hose
Thanks guys I finally got one that works great it was a Kelly Springfield hose PN 0008..
72 K20 Project now!
72 Blazer (Parts)
Old 09-24-2009, 05:15 AM   #10
petey-pablo
"THE GREEN GOBLIN"
Re: Radiator hose
Where did you buy it if you don't mind me asking and did you have to trim anything off of it, are the bends perfect like the 74-75BB hoses? What application did you get it for Vehicle Yr/Motor....I would like to get my hands on a good fitting hose just in case...
Thanks Pablo.
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 09-30-2009, 05:02 PM   #11
JCaldwell
Re: Radiator hose
Thanks Pablo.
Hey Petey I got it at the local Autozone I had to trim bout 3inches off the radiator end..no the bends arent the same as the 74 hose its actually a 70 K20 350sb hose but both ends are 1.75 and its really stiff it works perfect Ive been running the motor working the bugs out and havent had any trouble out of it.. The gates hose I had which was almost the same hose was actually sucking shut when I revd the motor up...Hope it works for you the only thing Petey my 72 has a 2in body lift so that helped me might hurt you..but defently get a Kelly Springfield no matter what you get..the guy at autozone said it was a goodyear brand
72 K20 Project now!
72 Blazer (Parts)
