Old 09-22-2009, 11:33 AM   #1
TDS-MN
Cool MPG check
Hey All,
Just refueled after a weekend trip, and was not that thrilled with my calculations.
Background, the truck is my '85 K-10, 3:08 gears, 700R4 ATw/ OD. 31x10.5R15 tires. stock 305 w/ quadrajet. Stock exhaust w/ custom cat-back duals.
Had to sit in traffic on the trip north. Calculated 10.55 MPG, including the highway miles, sitting in stop-and-go traffic for maybe 45 minutes, and misc driving around town. Highway speed was around 65 MPH, rarely over.
Checked what i got on the drive home, took a different route to avoid the traffic congestion and road work. Calculated 11.33 MPG. Travel speed was more between 60 and 65 tops this route. No stop-and-go congestion to be found on the simple 2-lane highway!
Both trips were with minimal weight, just myself, a cooler and a couple bags. Ran in OD for all of the travel.
I've recently replaced fuel pump due to failure. Also new cap, rotor, wires and plugs. Also reconnected the Electronic Spark Control module, and adjusted timing close to spec.
Granted that these trucks are far from aerodynamic, but does anyone think that I'm getting less MPG than I should running the setup i have? I've read on other forums of some people acheiving better mileage, and am curious how those of you on the forum here are doing with your trucks.
TomS.
TDS-MN is offline   Reply With Quote
Old 09-22-2009, 11:38 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: MPG check
31x10.5's are a pretty big tire to be hauling around.
I almost wonder with those big tires, a 3.08 axle, and 700R4 if you are running below the power band of the engine....
Did you notice your engine RPM at 65 mph?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-22-2009, 02:16 PM   #3
TDS-MN
Re: MPG check
I can double-check that tach reading, don't recall off the top of my head. If I were to GUESS, I'd say just a little above 2000 in overdrive, but don't quote me on that yet.
You raise an interesting point, though. When encountering a slight rise in grade the truck really loses momentum, and needs to downshift. Of course, then it's pulling 3000+ RPM.
These tires are relatively new, but from my understanding, were also OE size on some of the Trucks/Blazers. Have previously run a 235/75R15, but thought that my MPG back then was pretty poor too. Of course, I had the ESC system bypassed due to faulty controller, and that hurt performance. But these symptoms are not excusively since the current tires were added.
Old 09-22-2009, 04:36 PM   #4
Keith Seymore
Re: MPG check
Yes, they were available OE, but may have forced a higher rear axle ratio like a 3.73:1.
K
1979-1986
1986 - 2019
Old 09-22-2009, 05:36 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Re: MPG check
K
I agree, with the gear ratio and that tall of a tire with an OD tranny, you are killing your power band. This style of truck and engine design really likes the power band around the 2000 RPM and above area. You are basically idling down the road until you have to climb a hill and then the truck has to work twice as hard to get back to the power band and then do the work to move the truck. I had my son's truck running a 3.08 gear ratio and a 700R4 tranny with a lower profile tie and his MPG went to crap. We put in a 3.73 gear ratio and got his RPMs back up to the 2500 RPMs at 70 MPH and gained 3 MPG.
Frank
piecesparts is offline   Reply With Quote
Old 09-22-2009, 10:14 PM   #6
TwoFiftyShifter
Re: MPG check
My K20 with a TBI350 and 3.73 and NO O/D will get 15mpg highway..... You should be doing that. If you have hilly highways, do a trip in "3" and not OD and see if it helps.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 09-22-2009, 10:39 PM   #7
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: MPG check
This combo, in O/D, would be turning 1500 rpm at 65 mph!!!
In 3rd (1:1) it should be turning just under 2250 rpm at 65 mph.
I agree with TwoFiftyShifter, I bet your mileage would greatly improve by not using overdrive.
With 3.73's you would be turning around 2100 rpm at 75 mph in O/D.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-23-2009, 12:49 AM   #8
HOTFUN
HOTFUN's Avatar
Re: MPG check
The standard gear set on that year 4x4 10 series was 3.42 and most dealers around here ordered the 3.73's with that 305 and od. I didnt even remember that 3.08 as an option for the 4wd's. Another thing to question is the speedo gear correct since you increased tire size. You might be another 10% slower on the miles and speed after going up to 31" tires. You might try a GPS or mile markers and check your speedometer calibration. That can make another mile or two difference.
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 09-23-2009, 02:11 AM   #9
2tons of fun
Re: MPG check
haha, you said power band when refering to a 85 305!!!!!!!!!!!!
talk about boging down the motor, you might as well push 2.21 with stock tires.
i quite using o/d in mine just to make it drivable, it would bog down pulling up and on ramp.
being that it has a 208 and auto hubs you had better check the hub to make sure they are not fubard and locked.
2tons of fun is offline   Reply With Quote
Old 09-23-2009, 07:13 AM   #10
Keith Seymore
Re: MPG check
Originally Posted by HOTFUN View Post
... Another thing to question is the speedo gear correct since you increased tire size. You might be another 10% slower on the miles and speed after going up to 31" tires. You might try a GPS or mile markers and check your speedometer calibration. That can make another mile or two difference.
That's a good point, too.
K
1979-1986
1986 - 2019
Old 09-23-2009, 09:50 AM   #11
TDS-MN
Re: MPG check
OK, I confirmed on the drive home last night, it pulls 1800RPM at 65MPH.
Maybe I'll try a week without using O/D, just D, and see how my numbers work out then. I have not really checked the odometer against the mile markers on the road, I will try and do that next chance I get. I'm almost 100% positive that the 3.08 was what I saw on the glove box door sticker. I know that my tire diameter went from 29.1" to 30.8", but it seems that the speedometer must be pretty close to right on, with some rather un-scientific testing I have done so far.
"haha, you said power band when refering to a 85 305!!!!!!!!!!!!"
That did make me laugh out loud. I know it's not much to get excited about, but I'd like to be sure I'm getting all I can out of it, at least.
I have manual hubs, and they are unlocked.
I appreciate all of your comments, everyone.
Old 09-23-2009, 10:04 AM   #12
glock35ipsc
Re: MPG check
OK, so I was a couple hundred rpm off!
Then you will probably be around 2500 at 65 in 3rd. That's a good spot to cruise.
Bob
Old 09-23-2009, 11:22 AM   #13
piecesparts
Re: MPG check
The formula that I have makes the RPMs at 65 MPH is 1528 RPMs. This is with an OD tranny putting out at a .7 % vice a 1.0 output ratio.
If you are going 65 MPH at 1800 RPM, then something is different, than a 3.08 gear ratio. 1800 RPM would be a 3.73 gear ratio not a 3.08.
Take a stopwatch or a wristwatch and time what it takes for you to do a mile between several mile markers. It takes 60 seconds to do a mile at 60 MPH. (60 X 60 = 3600 seconds) If you do a mile in 55 seconds, then divide that into the 3600 and you get 65.45 MPH. So, 3600 divided by 50 seconds is equal to 72 MPH and so on.
Frank
Old 09-23-2009, 02:39 PM   #14
TDS-MN
Re: MPG check
Aw man, I hate math.
I will have to double-check the gearing ratio, was almost positive I had the 3.08 from what I read. I was hoping I had a little lower gear, but figured I'd make do with whatever it ended up being. From my research, either the 3.08 or the 3.73 were the options for '85.
So it sounds as if the consensus is that I should have the RPM's above 2000 for highway travel to maximize the engine's power curve (or lack there-of, LOL!).
It will be hard to train this old dog to shift it into D and not O/D. Struggled with it over the lunch hour, had to catch myself and go that extra click with the shifter.
Old 09-24-2009, 09:31 AM   #15
TDS-MN
Re: MPG check
Alright, so I drove it home and back to work in Drive, not O/D.
Was turing right around 2500RPM at 65 MPH. I think I was right near 2200 at 55.
Your thoughts were about right, though, as the truck seemed to be more in it's power band there, a little more throttle, and it started to move much more instantly than it would when running in O/D. It is different hearing the engine turing those RPM's, I'll have to get used to that I guess. I will keep this experiment going to see how my numbers calculate after this tank of gas.
I checked my odometer against the couple of mile markers that I did pass. First mile was reading almost right on, but the second came about a 10th too soon, the odometer was a little bit behind. I will need to expand on this check a bit more, but need to find suitable road to do it on.
I was going to verify the ID tag on the glove box door as well, to see about ratios, and confirm I read it right before. Still need to do that.
EDIT = confirmed the 1GU4 option on the glove box door, 3.08 axle gear. not saying the the calculated numbers lie, butI aslo don't recall my uncle eveer having the gears changed, nor any reason for him to do so, since it always had the 235/75 metric tires on it
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
