rear brake adjustment Eaton axkle
I need to back off the brakes on the rear axle. I assume I push the adjuster wheel keeper plate in and turn the wheel down???
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
What?
Re: rear brake adjustment Eaton axkle
That is correct.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Kind of how I remembered. Thanks for the info.
