09-22-2009, 03:40 PM | #1 |
bbadfred
Ignition switch removal
Ok so I am an idiot I cannot get the tumbler out of my Ign switch on my 67 gmc!! I inserted a stiff wire in the hole and I can feel the spring release but the key and tumbler won't come out. Any special way I should be pulling twisting or????
09-22-2009, 03:43 PM | #2 |
I am a Referee of life.
Re: Ignition switch removal
Keep at it.They tend to get a bit stuck,probably from being worn in for 40 years.I have had some luck lubing with a penetrating oil.Usually have to jiggle them pretty good to get them out.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-22-2009, 03:55 PM | #3 |
its all about the +6 inches
push on the spring loaded plate, and twist to the left. If for some reason you have an Acc position to the left (67 and early 68 don't) then put it in that position and start from there.
You do have the key in it while doing this right? |
09-22-2009, 04:06 PM | #4 |
The Older Generation
After you push the spring loaded pin in with the stiff wire and turn the cylinder further to the left you have to pull the wire out to finish turning it or it will bind. You can also turn it too far after you pull the wire out. That is when you have to wiggle the cylinder back and forth a little bit. If you wiggle it too much the pin will pop back out and you will have to start over. You should not have to put excessive turning pressure on it or push down hard on the spring loaded pin. Gentle and patience are the key words here... LockDoc
09-22-2009, 04:46 PM | #5 |
Leon... I've done this a dozen times, and I just learned something from your post. Thanks.
09-22-2009, 05:15 PM | #6 |
I never could get mine to come out, me and 2-3 other guys fiddled with that dang thing forever! I didnt think it was ever going to come out, untill he met Mr. Air Hammer! Gotta love those Door, ignition, glovebox key combo's! Use a 2x4 behind it to brace your dash, and plan on buying a new bezel and switch, Last resort only!! Hope ya get the angle on the dangle and dont have to use this method!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB Last edited by UltraBlue71; 09-22-2009 at 05:19 PM. |
09-22-2009, 06:22 PM | #7 | |
LockDoc
09-22-2009, 07:37 PM | #8 |
bbadfred
I will try again tomorrow. I did not take the wire out before pulling! Thanks will post tomorrow how it goes.
09-22-2009, 10:10 PM | #9 |
any way to do it without the key, just put a newer LT motor in ma truck and am using the newer steering collum, the ones with the key in them and the bright/dim switch and cruise control and air bags and all that. would like to get the old key dealio out of the way but no keys.
1970 Chevy C10 Short Stepside 4.3L LT 1965 Shelby Cobra AC 427 Comp Car 1965 Sunbeam Tiger 305 1984 Dodge D150 5.9L Magnum 1995 Dodge 3500 V10 1991 Ford 250 460 Last edited by Terakilla; 09-22-2009 at 10:10 PM. |
09-22-2009, 10:20 PM | #10 | |
LockDoc
09-22-2009, 10:29 PM | #11 |
landarts
On this note I spoke with a friend that is also trying to get his ignition out also and has been fighting it like crazy. He said that he had been trying for a couple of days and decided before he went in for the night he shot silicone spray in the ignition and let it sit over night. When he tried the next day it popped out first try. Maybe shoot a little spray-- let it sit over night -- give her a try......
09-23-2009, 12:59 AM | #12 |
Don't know if it's different on each year but on my 72 the switch itself has a small hole in the bottom that you can stick a small screwdriver in and pry (push handle towards firewall) the cylinder out. This is along with pressing the pin and turning to the left.
09-23-2009, 12:24 PM | #13 | |
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-23-2009 at 12:24 PM. |
09-24-2009, 06:23 PM | #14 |
bbadfred
thanks
10-02-2009, 07:39 PM | #15 |
bbadfred
Well sucess today!! I have let it sit for a week with rustbuster in it and today I pushed the wire in the hole turned the key to the left and it moved slightly and the tumbler slid right out!!!!!. thanks everyone for all your help!!!!
10-02-2009, 07:49 PM | #16 | |
Glad to hear you prevailed.. Mind over matter.. LockDoc
