Grandpa in the rustmobile...
my front rallys get dirty dirty black after about 2-3 days of being washed
Ok, i go out, wash my truck. 2-3 days later the back wheels still look great, while the fronts have a black coating on them. What is causing this, the whole truck looks good except for scummmy looking front wheels? are my brakes hangin up or what? i'll try to get a pic later for yall?
hope this is the right place to put this thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: my front rallys get dirty dirty black after about 2-3 days of being washed
Disk brakes will do that..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
geez!
its disgusting! anyway to get around this problem?
It's brake dust. Get higher quality brake pads and that will help out some. They make brake dust shields that go behind the wheels too, I've used them before with good results.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
It is one of two things you are either driving the truck hard and hitting the brakes hard to stop or cheap brake pads or calipers are not releasing..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Redefining LowBudget
when you did the disc convertion did you swap the proportioning vavle?? if not you maybe using all front brakes if you still using the drum/drum one
Its your brake pads causing it. change your pads to a low dust pad and it will lessen.
![]() Join Date: Oct 2001
ceramic pads are dust free! Advance Auto Parts, we sell them!
Things happen for a reason! |
new brake pads huh..
i did replace the proport. valve but replaced it with an old one....and i didnt replace the calipers..... how much are ceramic pads but they get nasty fast lol thanks!
Eat My Rust
Their maybe 10 bucks more? I get them anyways they perform better and can get hotter with out fading. No brake dust on my black wheels... Just dirt
![]() And I'm hard on the brakes all the time when on delivery. I know muh braking powahs Last edited by texanidiot25; 09-22-2009 at 10:04 PM. |
Try cleaning and lubing the sliders.If that doesn`t work you may have a frozen caliper or two.Two is unlikely,but if it isn`t pulling and both sides get equally dirty I`d think there`s something mismatched causing them to not release fully.it sounds like abnormal build up.
