Old 09-22-2009, 08:18 PM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
BB brake booster clearance question
Will the driver side tall BB valve cover clear the booster? Seems I read sometime ago there could be a clearance issue.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-22-2009, 10:37 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: BB brake booster clearance question
I think there are a couple of different height valve covers so it is a crap shoot. I guess the only thing you can do is get a measurement on the valve covers you want to use and measure the head to booster clearance...
LockDoc
Leon
Old 09-22-2009, 11:12 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
Most 'tall' valve covers are around 3 1/2 to 3 5/8 inch. It will be very close. I'm (was) running short aluminum M/T valvecovers and they are 2 5/8 tall and I had just about an inch between the edge of the booster and the top of the valvecover.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 09-23-2009, 12:44 AM   #4
Dynomutt
Dynomutt's Avatar
Not sure if the height changes with 71 BB mounts vs 72 BB mounts but I had 71 mounts and short covers and had plenty of room. I'm going back with 72 mounts so that may change.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 09-23-2009, 01:46 AM   #5
2tons of fun
and what size booster?
i have a 70, 402, small booster, with talls, and there is a ton more of room.
my 71 with 73+ motor mounts and the big booster wouldn't clear medium height.
2tons of fun is offline   Reply With Quote
Old 09-23-2009, 05:59 AM   #6
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
It shouldn't hit well mine didn't heres a picture my 72 with a 454BB with stock Booster but mine are not that tall I guess it depends on how tall you want to go.....I am also useing Stock 72BB Motor mounts if that makes adifference..
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 09-23-2009, 11:02 AM   #7
BossHogg69
motor exploder
BossHogg69's Avatar
got a pic of mine - see red circle, it's pretty close. I'm running BB motor mounts, not sure what year though.
and yes, my motor is ugly and my booster isn't hooked up... It's all scattered in a hundred pieces in my garage now, so that will change over the fall/winter!
Adam
Old 09-23-2009, 12:36 PM   #8
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Thanks for the replies. I am running 72 mounts but do not have the motor installed. I want to be able to service the valve cover gaskets if necessary.
Old 09-23-2009, 10:24 PM   #9
2tons of fun
like BossHogg69 i had those same covers and they are removable but you have to go in over the intak and roll them down over the rocker arms, you cant do them like a short cover.
