Old 09-22-2009, 10:26 PM   #1
soala70
soala70's Avatar
73-87 tublar arms fit ours?
found a great deal on some
bogey5
soala70 is offline   Reply With Quote
Old 09-22-2009, 10:34 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 73-87 tublar arms fit ours?
Yes,... but the balljoints are different.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 09-23-2009, 12:31 PM   #3
soala70
soala70's Avatar
so all I would have to do is change ball joints? difficult job ? or possible at all?
bogey5
Old 09-23-2009, 01:03 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You should be able to just slap some 72 ball joints and it will be good to go iirc..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-23-2009, 02:15 PM   #5
lolife99
lolife99's Avatar
Uppers are bolted in and lowers are pressed in,... normally.
What brand of arms are they?
Keith
Old 09-23-2009, 02:33 PM   #6
mindhive
Dont you also need the cross shafts since the 73-87 have rubber bushings and 67-72 have the metal screw in/on cap with the grease fittings?
mindhive is offline   Reply With Quote
Old 09-23-2009, 02:55 PM   #7
Hart_Rod
Hart_Rod's Avatar
Change the ball joints to 71/72 or you could change your spindles to the later model 73/87. You won't have to change cross shafts, either or will bolt up to the crossmember.
R/
Hart_Rod is offline   Reply With Quote
Old 09-23-2009, 10:35 PM   #8
soala70
soala70's Avatar
thanks for all the input got them on the way to me now and going to go with 73-87 drop spindles.
bogey5
Old 09-23-2009, 10:47 PM   #9
lolife99
lolife99's Avatar
Got any pics of your truck?
Keith
Old 09-24-2009, 10:52 AM   #10
soala70
soala70's Avatar
yea I will get some this weekend it is tore down except for cab but will put some on friday or sat.
bogey5
Old 09-24-2009, 02:57 PM   #11
texanidiot25
Eat My Rust
texanidiot25's Avatar
I think the hardest part about ball joints is getting them out of the spindle. One trick if you can't press them in, is to loosely bolt it to the spindle and put some wieght on the truck with the spring in place. It will pull the ball joint into the arm
texanidiot25 is offline   Reply With Quote
