Try again with pics
Anyone know if these will fit my 75 half c10. They are off a 73 454. Maybe out of a motorhome? They are listed as police package manifolds and are nodular iron. Anouther question- what is the best way to restore these?
Happy to be here
![]() Join Date: Mar 2000
Re: Try again with pics
I can't say for sure if they will clear on your application. I can tell you to restore them you can bead (or sand) blast them.
I really like the Eastwood brand Hi-Temp paints. They leave a nice "as cast" finish and can be sprayed or brushed.
I will be removing the smog tubes and plugging them and would like a factory look restore?
At the body shop.
They would look good with ceramic coating too
Didnt know you could ceram coat iron manifolds? The tube headers on my Chevelle are coated.
At the body shop.
Yes sir not sure on cost but ya
Gettin It One Pice At A Time
or what about sending them to TXfirefighter for a nice powder coating?
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
What is most durable?
In the Forgotten far North.
![]() Join Date: Jul 2007
Ceramic coating is much more durable on exhaust manifolds than powdercoating.
Powder coating is baked on at around 450 - 650 degrees and the exhaust manifolds can reach temps of up to 800 degrees and burn the powdercoating right off.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade Last edited by BLE 'BURBAN; 09-23-2009 at 01:47 AM. |
#10 | |
They have some powder coating that is tolerant up to around 1000 degrees now, but still wouldn't use it on the exhaust manifolds.
What do we get for $10?
It seems that I read somewhere that big block manifolds (older ones anyway) were all pretty much the same dimensions, except for some higher flowing Corvette manifolds that were totally different and wouldn't fit into other chassis. So if that's true, you should be all set.
Something else that is a little off topic, but if you're going to be removing the air pump tubing you could probably take a die grinder and clean up inside of the manifolds where the tubes come into them. There's probably a little bit of a restriction right there where the tube holes are. I did that on an old Chevelle I used to have. ![]()
1977 GMC K25 400/400/205 1989 Chevy Suburban R1500 350/700R4 (work beater) 1994 Chevy K3500 dually 454/4L80 1996 Corvette LT4 350/ZF 6 speed 2000 Bonneville SSEI Supercharged 3.8 Liter V6 1966 Chevelle 2 door sedan (Needs major repair ![]() Last edited by 77gmcjoe; 09-23-2009 at 05:49 PM. |
#13 |
Thanks, good idea. This wont be much more than a step up from a stock 454. 8.5-1, RV cam, 049 heads, performer intake, quadjet, dual exhaust. 3.07 posi.
#14 |
I found these advertised on the web for sale and had listed c10 73-87. Do they look the same to you?
#15 | |
![]() I don't know what the coating is on them, but it makes them look pretty good!
1977 GMC K25 400/400/205 1989 Chevy Suburban R1500 350/700R4 (work beater) 1994 Chevy K3500 dually 454/4L80 1996 Corvette LT4 350/ZF 6 speed 2000 Bonneville SSEI Supercharged 3.8 Liter V6 1966 Chevelle 2 door sedan (Needs major repair ![]() Last edited by 77gmcjoe; 09-24-2009 at 08:00 AM. |
#16 |
They are high nodular iron thats why they look different from the regular crusty iron. Granted mine need blasting but they have been out in the rain and heat for years and still look relatively good. Im sure they have something sprayed on. Not sure what either. Nodular iron is always the better choice.
#17 |
Moderator
![]() Join Date: May 2007
I use POR 15 hi temp exhaust manifold paint. I drive my truck daily and they still look brand new, even after 4 yrs. You can brush it on or spray it on. You can get it in cast iron finish (stock), bright aluminum, or black.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 09-24-2009 at 07:07 PM. |
