Your UncleBen
![]() Join Date: Dec 2002
I was wondering if anyone has used a 3rd Generation Camaro front sway bar on their truck?
Did you have to modify the bar to fit???? If so, what did you modify? Have any pictures of what you did?? Please post them if you could. Thanks alot guys. CHRIS
68 C10 shortbed -- Street/Strip ![]() |
14.1 @ 96MPH
All I have to say is 'Why?' when the bars that fit no problem are so plentiful...IIRC, pretty much anything '67-'87.
Project1970 - LS1 Swap Complete! ![]() |
Your UncleBen
The reasons are very simple.
1. I already have this bar, aka FREE. 2. This bar is MUCH larger than the stock CST bar that you can get. This bar I have actually came off a 1 ton truck that a friend of mine had on his 88 IROC ![]() 3. CST sway bars aren't all that 'plentiful' are they? Kind of like the overload leafs on some of the CSTs. I cant find those brackets anywhere. thanks again CHRIS
14.1 @ 96MPH
1. Doesn't have to be off of a CST. Any sway bar on any 1/2 ton (and maybe 3/4 but I don't know) made from '67 to '87 will work...
2. Eh? So it's a truck bar anyway? If it hasn't been modded, all you need are the brackets and it should bolt up...
4 speed, hurst shiftin
i think he meant it was off an 88 iroc originally, then put on a truck
Shane 1970 Chevy C10 |
#6 | |
14.1 @ 96MPH
If it was off of an IROC and then installed on a truck and he wants to put it on his truck...well, I don't know. In that case, I'd sell the bar and go grab a truck bar.
Your UncleBen
Hey guys,
One of you was right. It first was on a 1 ton flatbed truck (stock), then my friend took it off the truck and installed it on his 88 IROC-Z Camaro. That car was basically totalled so he parted it out. That is how I acquired the bar. He said the 1 ton truck was an 88+ truck. So I may just keep this one or trade it or sell it or something and get a stock 1 ton bar off a 67-87 truck. Would that be wiser than tring to make this one work? How much am I looking at for one of those bars from 67-87? thanks CHRIS
yes then it will work, if its truck bar, thats what it is anyways is a truck bar!
64-87 works off trucks not vans though good luck |
Your UncleBen
Thanks much!
lata CHRIS
