Ebay Junky
Opinion: Typhoon engine in a 72..
Im looking to put a 93 GMC typhoon engine into my 72 short bed 2wd. I was going to use a stock 700r4 so no awd. I really like this motor and it would def. be a unique swap. Also, since its essentially a small block, the swap shouldnt be too hard and the power is good enough to make this truck pretty quick. Your thoughts/opinions? And yes, i know this is not practical, but say i wanted to do it.
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
![]() Join Date: Oct 2005
Re: Opinion: Typhoon engine in a 72..
Sounds like a cool idea to me......I go with a build 200R4 for the better 1st - 2nd ratio spread. Probably help a little with keeping the turbo spooled up.
I've always loved the Cyclone and Typhoon.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Ebay Junky
Found a typhoon motor, has a main bearing knock however, shouldnt be too hard to rebuild, guy hasnt given me a price yet, its just like rebuilding a regular 4.3 v6 right?
![]() Join Date: Jan 2001
If my memory serves, the Typhoon and Syclone only had about a 400 lb. load rating. I'd check the curb weight against the weight of your truck and how you intend to use it.
Ebay Junky
Just going to use it as a cruiser, not going to pull anything. I think a shortbed 2wd 72 pickup weighs about the same as an awd typhoon.
Gearhead
I would say that the load rating had to do with the full time t-case, but I could be wrong. Sounds like a cool idea to me, and I havent seen one yet, so unique as well. Go for it!
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
sounds cool.... if ya can afford it then go for it.... def. different....
Sounds cool to me.
Eat My Rust
When you consider that this turbo version puts out way more than the normal 4.3L V6 that they put in the bloated GMT800s and early 900s, this motor will be fine.
The 4.3L V6 thinks it's a V8 when it comes to torque, it will be fine. |
I like the idea. Always liked the typhoon
Just make sure you get the wiring harness and computer.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Ebay Junky
so 200R4 trans vs. a 700R4 with this set-up? What kind of gears should best? looking for quickness, not top speed, also, i will be running a 20" wheel
#13 |
3.73:1 seem to be the best choice when using an overdrive auto. Have a 700 in mine with 3.73......no complaints.
#14 |
That built will be totally
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#15 |
That would be super cool! Have you seen that one guy on youtube that has his cyclone all hopped up and rippen down the street? I say go for it!
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
