Old 09-23-2009, 07:32 PM   #1
ipaintem
under the hood wiring pics
how about some detailed wiring pics from under the hood. water temp, oil press, alt, ect where did you run them? thanks
ipaintem is offline   Reply With Quote
Old 09-23-2009, 09:50 PM   #2
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: under the hood wiring pics
I like to run the wiring from the firewall on the drivers side under the fender and then to the engine near the alternator in a nice, neat bundle and then branch them out from there.
Keeps it organized and very easy to disconnect if an engine swap is in store.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 09-23-2009, 09:56 PM   #3
lowrollin70gmc
Too many projects
Here's my Chevelle for example. Note the wiring near the power steering/hydroboost hoses. If I need to pull the motor I can disconnect the senders and drape the harness over the fender and then reinstall in about 5 minutes.
It runs under the alt, over the water pump and the intake to all sensors:
Oil pressure, water temp, fan temp probe, choke, HEI, alternator, tach, etc.
Andrew
