Old 09-23-2009, 09:01 PM   #1
Dan 67 Chevy LWB
Rearend ? along with Gear ratios.
What different rear nds came in the 67-72 trucks? Did it vary depending on if it was an I-6, SBC or BBC. Also what gear ratios were offered.
I have a truck that started as an I-6 and 3 on the tree. If i remember from few years ago when i figured it up, my rearend as a 4.10 gear.
I'm in the process of converting to a BBC. So want to make sure or see if it is best if I change my rearend.
Dan
67 Chevy LWB, Small Window - In the process of being rebuilt. Small Block is coming out & I'm gathering parts to switch to a Big Block 496.
Dan 67 Chevy LWB is offline   Reply With Quote
Old 09-23-2009, 09:08 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Rearend ? along with Gear ratios.
Is it a 1/2 ton or 3/4 ton?
I am sure that 3.73's were offered in the 1/2 tons with l6, but I am not sure what else was offered.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-23-2009, 09:21 PM   #3
lilred67
lilred67's Avatar
i've only seen 3 different ratio's for 67-72 1/2 ton trucks.
3.08
3.73
4.10
lilred67 is offline   Reply With Quote
Old 09-23-2009, 10:25 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
C/10;
3.07
3.73
3.54 (very uncommon and not in the books)
4.10
C/20
3.54
4.10
4.11
4.56
4.57
5.13
6.something.... does it even matter at these RPMS?
C/30
4.10
4.57
5.13
6.something
Old 09-24-2009, 12:12 AM   #5
into69z
"brand new second-hand"
into69z's Avatar
If it helps-I installed a rearend out of an 86 3/4 ton that came stock with a 3.23 gear. I too changed to a big block and had 4.10 in my 1969. It runs much better-70mph is achievable and the gas gauge doesn't move as much-but I still average 10-12mpg.
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 09-24-2009, 02:01 AM   #6
2tons of fun
as far as the rear ends them selfs you would have a 12b in a 1/2t leaf or coil. and a rare d60.
a coil 3/4t would have a d60ff
a leaf 3/4t would have a eaton 052
no coil 1t,
1t srw would have either the eaton 052 or 072
1t drw has the eaton 072.
2tons of fun is offline   Reply With Quote
Old 09-24-2009, 06:12 AM   #7
Longhorn Man
on 3/4 ton, eaton HO52 was that norm, unless big block was optioned, then the dana. Rear suspention had nothing to do with it.
Then on the one ron, no coils, no dana, just the Eaton HO52. There were some options for the heavy duty c/30, but far and few and pretty much not important to anyone here.
Old 09-24-2009, 09:56 AM   #8
Dan 67 Chevy LWB
This is a 1/2 ton with coils.
So more then likely I have a 12 bolt. I guess i will have to climb under the rear and make sure.
That is also good, as i know there is aftermarket parts available for the 12 bolt.
Dan
Old 09-24-2009, 10:19 AM   #9
69GMCLonghorn
69GMCLonghorn's Avatar
Might be a dumb question, but is the "Eaton" rear end also called a "Corporate" rear end? Or are they 2 different entities?
69GMCLonghorn is offline   Reply With Quote
Old 09-24-2009, 12:41 PM   #10
profe56
kindergarden question what it means SBC and BBC
profe56 is offline   Reply With Quote
Old 09-24-2009, 12:43 PM   #11
69GMCLonghorn
Small Block Chevy
Big Block Chevy
(GEEZ I hope that's right! HAHA)
Old 09-24-2009, 01:14 PM   #12
profe56
thank you
Old 09-24-2009, 01:32 PM   #13
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Different entities. Corporate is the 10-12-14 bolt that you see under every Impala/Chevelle/Nova in the world. The Eaton HO52/72 rear is a truck unit with a hemispherical diff cover. It looks like half a basketball with a fill plug installed.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 09-24-2009, 03:54 PM   #14
Longhorn Man
It is technicly a coperate rear, with an eaton diff. The rear end assembly was built in house, or under a contract specificly for GM while the Dana was built by an outside vendor and sold to other companys in addition to being sold to GM.
Old 09-24-2009, 03:55 PM   #15
Longhorn Man
Side note... the car 12 bolt and truck 12 bolt are not quite the same, double check aplications of parts you buy for the truck unit.
Old 09-24-2009, 05:21 PM   #16
nsuengineer06
nsuengineer06's Avatar
GMC pauls has a pretty good write up on the rear ends that gives the stamp codes and the corresponding gear ratios.. Located Here.
1967 C10 LWB 454/TH400
1971 C10 SWB
1984 C30 LWB Dually 454/4 spd 4:10
2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison
nsuengineer06 is offline   Reply With Quote
Old 09-24-2009, 05:36 PM   #17
cparman
sharp as a marble
I asked this question in the driveline section, and got an answer, sort of. I want to change the ratio from 3.73 to 3.42. My reading says that I will need a 3.07 carrier to accept the 3.42 gear. Is this correct. I have read here that most do not recommend going to a 3.07 with a 700r4 trans. Don't need a posi, cause my wife thinks I am over driving like I was 16 again. She accused me of that when I had my 500hp Chevelle. I took it as a compliment!
cparman is offline   Reply With Quote
Old 09-24-2009, 05:40 PM   #18
nsuengineer06
cparman I have seen this discussed and don't remember all of the specifics, but I do know that you can buy certain gears for different carriers.. I think I saw them in Jegs or Summit, but it will specify which carrier it will fit. For instance say you have a carrier that will take up to a 3.42, but want to put in a 3.73, if you look hard you can find a 3.73 that is MADE to fit the 3.42 carrier.
1971 C10 SWB
Old 09-24-2009, 07:50 PM   #19
cparman
sharp as a marble
NSU, I am aware of this with the 12 bolt car rear ends. Just hoping someone can help me spend my wife's 30th anniversary money just once. Dang women just do not understand gear sets. ALTHOUGH they can order 3 tops, and pants on line and send them back 14 times and justify the shipping!!!!!!!!!
Old 09-24-2009, 09:00 PM   #20
nsuengineer06
lol yea I know all about that! I thought they had those gear sets for the truck carriers too. I may have been mistaken. Ya know, if you just need somewhere to send that money, I sure need a set of heads for my 327!
1971 C10 SWB
