Old 09-24-2009, 07:32 AM   #1
eric67m
eric67m's Avatar
Radio delete - broken tab fix
Im in the process of re assembling my cab interior. I went to put on my radio delete plate. One side was missing a tab and the other side did not want to go in. So I made these up during my break at work. I used 18 g stainless, 8-32 stud weld, add a body fender washer and a nut.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 09-24-2009, 10:27 AM   #2
69GMCLonghorn
69GMCLonghorn's Avatar
Re: Radio delete - broken tab fix
That's pretty creative, and nice welding too!
On mine, I found a really good replacement for that plate... It's called a RADIO!!
69GMCLonghorn is offline   Reply With Quote
Old 09-24-2009, 10:49 AM   #3
red71c10
The Red Menace
red71c10's Avatar
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 09-24-2009, 01:44 PM   #4
mclairmo
Very nice.
mclairmo is offline   Reply With Quote
Old 09-24-2009, 02:16 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Nice work.
--Josh
Old 09-24-2009, 06:34 PM   #6
eric67m
eric67m's Avatar
Thank you for you comments.
The stud welder is really easy. Set the power knob to the size screw you are using. Put the stud where you want it, press down and pull the trigger.
In a car I need a radio. In my truck I really dont miss it. I can just space out, figure out problems.
