09-24-2009, 12:46 PM | #1 |
Front sway bar pictures
Can I see pictures of a front sway bar in a C10 69 1/2 ton
09-24-2009, 02:33 PM | #2 |
Re: Front sway bar pictures
Not sure if this is the angle you need, but it's all I have for now.
09-24-2009, 03:10 PM | #3 |
thanks: 69 stepbed now I can do the following questions.
My c10 69 do not has sway bar so I saw here in the forum that you can use one of the newest trucks then I have one of the 73-87 version but I dont have the brackets that hold the bushings and sway bar at the chassis. Do you know where can I find it? this morning I saw two differrent sets but they´re sold complete and I only need the brackets |
09-24-2009, 03:19 PM | #4 |
This is the one I added from CPP......
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
09-24-2009, 03:35 PM | #5 |
I ordered mine from Early Classic
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
09-24-2009, 04:40 PM | #6 |
The oddest Todd around
Yeah... Early Classic has the brackets for lowered vehicles so that you don't hit a curb with your sway bar. That's the one I went with.
I got my sway bar off of the parts forum on here. I think it was the one for a 1-ton, 1 1/4 inch or some such...
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? Last edited by toddtheodd; 09-24-2009 at 04:41 PM. |
09-25-2009, 06:03 AM | #7 |
English Chevy Owner
Heres mine, came off a 73 up1 ton that started life as a camper and ended up as a flatbed wrecker. Its enormously thick and weighs a ton as I had to carry it for nearly a mile back to my car when I picked it up from a guy at a big car show. The original brackets were pretty bashed about and had been repaired so I went with a set of the lowered brackets and poly bushes from ECE. Took me a couple of hours to fit and most of that was taken up by grinding and chiseling the rivets off the frame. I even gave it a coat of red paint!
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
09-25-2009, 09:53 AM | #8 |
Try spinnin 4 rear tars
I picked up a bar and hardware from the junkyard from a 73-87 3/4 ton truck. Ordered new sway bar mounting brackets from (I honestly don't remember, but they were factory height units), bought new bushings and installed. I had to remove 2 rivets for the crossmember and replace with bolts. Super easy mod/install and made a world of difference!
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
09-25-2009, 01:06 PM | #9 |
Sweet Pics, I needed those too. Winter project #1
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
09-25-2009, 01:09 PM | #10 |
09-25-2009, 02:54 PM | #11 |
Retiredoldfarttankerguy
Surprise! Taking the front suspension out of my 68 projo and found it has a sway bar already! cool...
I don't remember the previous trucks having one..? This being a 250 L6, I didn't expect it? But, I wasn't bagging those either... ??? So, any nuances to bolting this back up to my LCA's after the bags are added up front, and the disc upgrades are done? BTW - the front right drum had LOTS of parts collected at the bottom of the drum as I pulled it off yesterday! Glad to be making the upgrade to cupped lca's, discs, drop spindles, and a couple BAGGY'S
________________________________ Swany Current 67-72 truck projo - #5 of 6 and #1,000,000... of all the other things that keep me from working on it. Fav - local parts shop. They ship world-wide. www.fillingstation.com |
09-26-2009, 02:00 AM | #12 |
Thank you so much to every one place pictures, now is imposible not understand, more easy to understand I don´t think so.
