Junior Member
67 GMC Rad support
Is there a difference between a 67 GMC rad support and a 72 GMC rad support?
Thanks Dustin
72 GMC 3/4 ton Custom Camper 5.3 ltr 4l60e 72 Chevy Blazer 4x4 327 4spd 70 Olds Cutlass supreme 455 4spd m21 |
Re: 67 GMC Rad support
I think they are different , but check out a Brothers catalog on-line to be sure.
They break down all the front end parts verry well. ![]() |
![]() Join Date: May 2006
The only difference I know of is the 67 and 68 supports had a row of nuts at the bottom for fastening the splash pan that went between the grille and support. The newer ones didn't have the splash pan.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! Last edited by RustyParts; 09-24-2009 at 05:44 PM. |
70 Chevrolet=Obsession
On a Chevy, a 67-68 Radiator support is different than a 70-72. The mounting bolt cushions are small on the older model. I think this is also true for GMC.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
67/67 Chevy & GMC supports are different.They have the row of mounting nuts for the pan "and" are taller,requiring the shorter mounts.You need to keep the mounts with the support they wear meant for.It`s more than just the different hole size.
