Old 09-24-2009, 06:02 PM   #1
kenm78
Broken Down
kenm78's Avatar
Torque Converter Lockup.
According to my vacuum chart there is a transmission lockup converter vacuum switch. I am thinking this is supposed to lock up my converter when It needs to. Well unfortunately when I bought it I found a toggle switch and I manually have to turn the lock up on and off. Gets old after a few times. Does anyone know where this switch might be located, or have a picture of what it looks like? I would like to try to get it working so I don't have to flip the switch every time.
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 09-24-2009, 07:33 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Torque Converter Lockup.
The switch is on the driverside firewall. It's next to the fusible link. It's normally covered/behind by a plactic wire wrap. LMC has the part available.
It looks similiar to the ECM timing switch. Switch on the left side.
Opss forgot this link: http://www.73-87.com/7387garage/drivetrain/lockup.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 09-24-2009, 08:11 PM   #3
kenm78
Broken Down
kenm78's Avatar
I just looked through the LMC online catalog I couldn't find it. Were did you see it at?
kenm78
1982 Chevy 4X4
Project truck
Old 09-24-2009, 08:49 PM   #4
joe231
joe231's Avatar
What year truck?
On my '80 the vacuum switch is located on the fire wall just above, and towards the passenger side a bit from the brake booster. The lock up wiring runs through the vacuum switch and also through a set of contacts in the brake switch also
CHEVY ONLY
Old 09-24-2009, 09:08 PM   #5
gchemist
gchemist's Avatar
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=136
Old 09-24-2009, 09:08 PM   #6
S10Fan
Old Heap Driver
700R4?
I'm wondering if the PO installed a "Lock Up" kit from TCI. If so,you could re-wire the toggle switch to a switch similar to a brake light switch. The new switch would operate with your brakes. Some research would be needed to make sure.
http://www.tciauto.com/
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 09-24-2009, 09:09 PM   #7
kenm78
Broken Down
kenm78's Avatar
Yes mine is a 80 I found a little switch it the area to the passenger side of the brake booster near a junction block. It has a single connection on one side and a vacuum hose on the other. I'm not sure why the previous owner wired in the toggle switch instead of using the OE vacuum switch. Any way to test it and see if its working? I guess now I have to try and figure out how to hook it back up to OE??
kenm78
1982 Chevy 4X4
Project truck
Old 09-24-2009, 09:30 PM   #8
kenm78
Broken Down
kenm78's Avatar
Originally Posted by gchemist View Post
I must be blind all I see is the modulators, kick down solenoid inside trans (TH400), trans control solenoid (700R4), trans spark control (TH350), and trans temp switch (700R4).. I don't see it??
kenm78
1982 Chevy 4X4
Project truck
Old 09-24-2009, 09:31 PM   #9
kenm78
Broken Down
kenm78's Avatar
Originally Posted by S10Fan View Post
700R4?
No I have a TH350 Tranny.
kenm78
1982 Chevy 4X4
Project truck
Old 09-24-2009, 10:58 PM   #10
joe231
joe231's Avatar
do you have a mity-vac?
you can run the engine and check it with an ohm meter, at idle it should have continuity (contacts closed), rev the engine and the contacts should open. Mine, IIRC, has 2 green wires. one wire goes to the brake switch and the other goes to the transmission.
do you understand how it is supposed to work?
TH350C?
I have a 350C in my '80 and I just recently hooked it back up, so if you have any specific question let me know
CHEVY ONLY
Old 09-24-2009, 11:45 PM   #11
gchemist
gchemist's Avatar
Oh, you can use the same switch as a 700R4. All it does is is lockup the converter.
Old 09-25-2009, 05:48 AM   #12
kenm78
Broken Down
kenm78's Avatar
TH350C?
You wouldn't have a copy of the wiring schematic? That would help me understand it better. I traced the two wires back to the cab and one of them that I am assuming connects to the brake switch is disconnected I hav not tracked down the other one yet. The schematic I have isn't corrrect. Thanks for the help.
kenm78
1982 Chevy 4X4
Project truck
Old 09-25-2009, 08:42 AM   #13
joe231
joe231's Avatar
there are 2 different transmissions...mine is like the first one.
http://67-72chevytrucks.com/vboard/s...ht=350c+wiring
http://67-72chevytrucks.com/vboard/s...d.php?t=216865
CHEVY ONLY
