How did you do your undercoating???
HI GUYS
Just woundering how some of you under coated your trucks with know lift? just need some ideas Thanks Jeff
more ideas than money
Re: How did you do your undercoating???
Wear old clothes, eye protection, and a hat. Slide under and go at it.
![]() What type of undercoating are you using? What prep work do you plan on doing to apply it?
Randy1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
Instead of using that rubberized undercoating I used bedliner on the whole underside of my truck. I didnt want to use that rubberized stuff because I had to scrape it off the bottom of the cab and it is NASTY stuff...in my opinion.
![]() Join Date: Sep 2008
Just like blue 72 said use the duplicolor truck bed coating in a aerosol can wont crack or peel like undercoating
Once a Marine Always a Marine OOH-RAH GM Fanatic 1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!" 1986 c30 camper special 454, th400 (for sale) 1984 K10 Big Ten (project) needs motor 1984 C10 355, 700r4, (project) needs shortbox bed |
| Bookmarks |
