Old 09-24-2009, 08:04 PM   #1
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Can someone measure stock rear springs?
I need a height measurement of stock rear springs please.
Or if you have drop springs can you measure those.
I have a pair that are 12" high and need to know how they compare
to stock height.
Todd
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 09-24-2009, 09:56 PM   #2
nsuengineer06
nsuengineer06's Avatar
Re: Can someone measure stock rear springs?
I can do it for you tomorrow after work if I can remember.. lol I've got a set of stock springs laying in the shop.
1967 C10 LWB 454/TH400
1971 C10 SWB
1984 C30 LWB Dually 454/4 spd 4:10
2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison
nsuengineer06 is offline   Reply With Quote
Old 09-24-2009, 10:04 PM   #3
BCOWANWHEELS
i can measure a set now that are stock but there installed ok with that ?
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-24-2009, 10:13 PM   #4
BCOWANWHEELS
todd,
my stock (1971 ) truck sitting empty ( c10 lwb ) the springs are 9 3/4" tall
Old 09-25-2009, 06:36 AM   #5
retodd7711
retodd7711's Avatar
Hey guys.
Even if you have a set of drop springs.
I'd appreciate a measurement.
Just say 2" drop X" tall
She can't cook
So forget her.
My old farm truck
Old 09-25-2009, 04:13 PM   #6
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Anyone have the height of stock or drop spring that have not been installed?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-25-2009, 04:47 PM   #7
My Alter Ego
Check the ECE website, if memory serves they had height info listed for stock springs as well as lowered. I recall a measurement of 13" for stock springs however don't remember if that was for a 1/2 or 3/4 ton. Good luck.
My Alter Ego is offline   Reply With Quote
Old 09-25-2009, 08:34 PM   #8
KMACD71
KMACD71's Avatar
I measured a set I have in my shed and they're both 12.5". I put drop springs on so I assume these were probably the original 38 year old springs. Closer to 13" is probably what they started out as way back then. The truck is a 71 1/2 ton. Hope this helps.
KMACD71 is offline   Reply With Quote
Old 09-25-2009, 09:05 PM   #9
nsuengineer06
I measured my set that I took off the other day. They measured about 12-3/4"... Remember, these are like 42 years old!
Here ya go.
1971 C10 SWB
Old 09-25-2009, 09:13 PM   #10
Ray Rust
Ray Rust's Avatar
I just measured a brand new set of drop springs , that I have in the shed they measure 10inches and from memory they were 3inch drop ... hope this helps Cheers Ray
Ray Rust is offline   Reply With Quote
Old 09-26-2009, 09:17 AM   #11
retodd7711
retodd7711's Avatar
Thanks guys for all your help.
If anyone else has a set I'd appreciate you chiming in with a measurement.
Todd
She can't cook
So forget her.
My old farm truck
Old 09-26-2009, 10:21 AM   #12
Richard H.
Spanked once
Richard H.'s Avatar
If I can find them I will measure my old springs but my spid for my 71 c 10 said Hvy Susp. The picture I dug up is the new vs old springs for a 4" drop. The thing at the time that got my attention was the old spring was made of heavier stock. Just sayin that may be a difference also in stock springs as to why yours measures 12".
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 09-26-2009, 12:30 PM   #13
Richard H.
Spanked once
Richard H.'s Avatar
I did find my old ones and they do measure 13" and are made of 3/4 " stock. If yours are like 11/16 or 5/8" at 12" , I would guess they are for a 2" drop?
Old 09-26-2009, 03:39 PM   #14
vegaschevy
That is because the taller spring will be softer. think of it as a 3 foot bar un coiled versus a 5 foot bar. the 5 foot bar will bend easier. So by using a thicker rod it stiffens it up a bit over a 4" drop spring. the shorter spring is essentially a shorter rod with equal coils so it can be thinner rod. This is where the problem comes in with what he is trying to do. I think he wants a drop from cutting his springs. his measurements might get him in the ball park but more then likely they wont.
Coil spacing, rod diameter, rod length all take in to account of a springs rate and static and installed height.
vegaschevy is offline   Reply With Quote
Old 09-26-2009, 06:04 PM   #15
retodd7711
retodd7711's Avatar
Unhappy Re: Can someone measure stock rear springs?
You cannot cut the rear springs as you need the smaller coil on top and bottom.
Here's what I'm trying to do.
I bought a set of springs we thought were a 3" drop.
When I placed them next to the stock springs they were the same height.
When I installed them on my truck, the ride height was the same.
I know the new springs have a smaller diameter rod, but I think that is due to 40 years advancement in metallurgy and heat treating.
Make sense?
Site will not let me load pics
She can't cook
So forget her.
My old farm truck
Old 09-26-2009, 06:12 PM   #16
vegaschevy
Make sense?
how many coils are on each spring? that has a lot to do with them as well.
Old 09-26-2009, 07:51 PM   #17
retodd7711
retodd7711's Avatar
Same # of coils (7)
She can't cook
So forget her.
My old farm truck
Old 09-26-2009, 07:53 PM   #18
retodd7711
retodd7711's Avatar
Toilet bowl cleaner-Excellent rust remover
Oven cleaner-excellent degreaser
Coors Light-excellent lubricant!
She can't cook
So forget her.
My old farm truck
