Old 09-24-2009, 09:39 PM   #1
zac
zac's Avatar
Is there an NP203 posi?
Since the NP203 acts as an open differential when not locked, has anybody ever made a posi (limited slip, whatever) for it? When not locked, it sends all the power to the axle with the least traction, or with no driveshaft. Why not have a posi in the internal diff that sends the power to the axle with better traction? I may be missing something simple here.
zac is offline   Reply With Quote
Old 09-24-2009, 10:50 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Is there an NP203 posi?
That's what the loc selection is for...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 09-24-2009, 11:20 PM   #3
2tons of fun
even then i have never had it stall all but one tire.
2tons of fun is offline   Reply With Quote
Old 09-25-2009, 06:55 AM   #4
The term differential is used as a descriptive, but there are no simularities to how a rear works.It comes down to the axle differential when controlling individual wheel spin.
All I know about 203s is everyone I ever saw was converted to part-time.guys in the mountains hated them and blamed them for causing wrecks when they hit a slick patch on a curve.When the front kicks in unexpectedly it pulls straight.Other than that it`s just a weak design that eats gas and requires higher maintainence.
Old 09-25-2009, 09:50 AM   #5
Burt4x4
Burt4x4's Avatar
The short answer is no.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 09-25-2009, 06:11 PM   #6
LONGHAIR
The typical clutch-type "posi" doesn't do that either....
It just ties the two axles together with friction plates that allow some slipping so that the "differential" action is still maintained.....unless the traction available to the tire is less than the clutches.
It is not capable of "sending" power to one side or the other, it is just making it harder for the differential action to work.
It is not locking anything.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-25-2009, 11:32 PM   #7
2tons of fun
have you ever had one apart?, they ARE a differentail. to a T
have you ever pulled on of the drive shafts off with out putting it in loc? just like a diff, once the resistance is gone it sends all the power in that dirrection.
Old 09-26-2009, 12:18 AM   #8
Critter
Future TOTM Winner
Critter's Avatar
As far as the "internal posi" goes, isn't that kinda what a newer style SUV/Denali Truck All-wheel drive case does? I don't know if that is anywhere close to being correct, I just always mentally pictured it doing something similar to that.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 09-26-2009, 06:49 AM   #9
Answer 1: No,I`ve steered clear of them.Never liked them.
Answer 2: What I meant was,although they both differentiate in the same way(result),the 203 has no effect on the wheels.The 203 differentiates power from front to back(axles) and the third member differentiate from side to side(wheels).
Answer 3:No confusion in Burt`s answer...No.
Old 09-27-2009, 08:56 PM   #10
2tons of fun
yes, the 246 are essentaily a friction posi, and just like a friction posi they wear out and lose grip.
