Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-24-2009, 10:13 PM   #1
skeeterbug
skeeterbug's Avatar
elec. fuel pump suggestions needed
ok im a couple days out from completing my frame & suspension rebuild, about to order alum. fuel cell from summitt or jegs while im at it converting over to elec. fuel pump anyone with good luck on particular brand(s). i think i can figure out the hose &fittings needed, mounting tank doesnt phase me my main concern is i want a reliable pump without all that whinning, it sounds cool at first but after a while it gets old. my cousin's 383 powered s10 drag racer is noise as hell, you can hear his even with the truck running and hes running long tubes w/ flowmaster race mufflers, gooooodddd goddd!
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 09-25-2009, 12:25 AM   #2
team39763
Re: elec. fuel pump suggestions needed
I have a Mallory 110 pump on my truck and it's pretty quiet. I haven't had any problems out of it either. I noticed that when you deadhead this pump it gets a tad bit louder. I'm running a return style regulator with mine so it keeps it's usual low, barely audible hum.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 09-25-2009, 08:41 AM   #3
skeeterbug
skeeterbug's Avatar
what do you mean my deadhead, run at maximum gpm?
2013 best 7.39
2014 best-7.38
Old 09-25-2009, 12:31 PM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
The 110 'kit' comes with a deadhead regulator (you don't have a return line to the tank like in a return style regulator) The Malloy fuel pumps are BUNCHES quieter than the Holleys. I've ran them on the street and on the strip for a long time and only had a couple failures.
I ran a single 110and dedhead regulator up to 580HP with an-6 line,,, and can PROVE IT. You don't have to go stupid overkill to feed even a serious motor, BUT,,,,,, if you have plans of any future go faster faster faster goodies and thinking above 600HP,, step up to the plate with an-8 right off the bat will save you $'s.
Above 600-650HP I'd highly suggest a Mallory 250 alcohol pump (the alcohol pumps are hard anodized to fight corrosion is the only big difference) and the Mallory 4307M return style regulator. Probably the best out there right now.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-27-2009, 03:09 PM   #5
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
I personally like the Aeromotive A1000 w/ return regulator.
I have also found out never hard mount your pump it just makes the noise worse. I install rubber isolators on all my pumps. super quiet.
http://www.summitracing.com/parts/AEI-11101/
68 C-10 KID is offline   Reply With Quote
Old 09-27-2009, 03:34 PM   #6
team39763
By deadhead, I meant running the fuel line with no return, in other words, the fuel deadends at the regulator when the correct pressure is built up. Also, I have my Mallory mounted directly to the frame and it's still not that bad. So I'd agree the Mallory pumps are nowhere near as loud as the Holley pumps(even with the isolators).
Old 09-27-2009, 05:38 PM   #7
skeeterbug
skeeterbug's Avatar
thanks for the heads up guys
2013 best 7.39
2014 best-7.38
Old 09-27-2009, 09:18 PM   #8
Wild83C10
Wild83C10's Avatar
I am a fan of Aeromotive as well. I haven't used anything else, but the aero's are somewhat quite and a few of my friends have switch their failing/loud holley's for the aeromotives and haven't looked back since.
I also agree with Marv D. For the couple of extra dollars run the 8an and never worry about whether it will support your motor or not.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 09-27-2009, 09:41 PM   #9
skeeterbug
skeeterbug's Avatar
ok what all should i need to purchase to do an elec. fuel pump install. running 750 holley dp vac sec if that helps, will be using summitt alum cell 20 gal.
2013 best 7.39
2014 best-7.38
Old 09-27-2009, 11:41 PM   #10
wheatlandbrawler
wheatlandbrawler's Avatar
something else you might want to take into acount with the mallory's and the holley's is that they are rotary vein fuel pumps any amount of moisture for a sustained amount of time will cause the veins to freeze up and you will lose fuel pressure or the pump will just quit all togeather, the aeromotives dont have this problem but are considerably more exspensive, and a MOST DEF on the 8an... some day if you step up the cubes you will know the fuel is their if you need it, might as well do it the first time instead of buying two dif sizes fuel line. GOOD LUCK!
1968 swb RIP 408. 388 roller monster mouse, richmond 5 speed. and alot of the stuff that makes you happy. build link. http://67-72chevytrucks.com/vboard/s...d.php?t=389826
wheatlandbrawler is offline   Reply With Quote
Old 09-28-2009, 08:12 AM   #11
Fisher-Racing
Fisher-Racing's Avatar
Skeeter
i have tried about every kind of elec fuel pump made, i have had really good luck with the Aeromotive, but i my pick of the litter is Magnafuel these things are top notch, and like the other guys said if you will put the rubber isolators between the pump and what ever you mount it to --quiet as can be, but man get a pump with a return,, it runs from your pump over to your fuel cell,, keeps fuel moving and does not build up heat, the pump will last a lot longer,
well just my 2 cents for what that is worth
Fisher-Racing is offline   Reply With Quote
Old 09-28-2009, 06:13 PM   #12
Wild83C10
Wild83C10's Avatar
Any particular reason you are switching to electric?
Where are you mounting the cell?
Off the top of my head you will need:
regulator
quality fuel line and fittings
pre and post filter
return line is probably a better idea for a street truck
I recommend a shut-off valve before the pump.
turbo=
Old 09-28-2009, 09:45 PM   #13
djracer
djracer's Avatar
I ran two mallory pumps a 250 on the motor and a 110 on the nitrous. They worked great but I'm swapping to a Magnafuel 500 to lose some weight and some plumbing.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-29-2009, 07:21 AM   #14
skeeterbug
skeeterbug's Avatar
well i figured i would go ahead and swith to electric now while its easy to do w/ the body off and all. plus next year i plan on punching the motor out to a 383. the new fuel cell will be mounted in between the frame rails under the bed. the cell comes w/ -8 inlet/outlet fittings so i guess i will need all -8 fittings, lines, and cuplers to plumb it up correct? by shut off valve do you mean manual or some kind of safety/ electric.
2013 best 7.39
2014 best-7.38
Old 09-29-2009, 08:34 PM   #15
Wild83C10
Wild83C10's Avatar
Just some food for thought, but a good mechanical pump will handle a typical 383.
Most electric pumps are pushers and the manufacture will recommend you mount it below the cell so the fuel is gravity fed from the cell. I recommended a manual shut off if you need to work on the fuel line, but if the cell is below the plumbing then you done really need one.
turbo=
Old 09-29-2009, 10:35 PM   #16
ripdog28
ripdog28's Avatar
While on the topic, anyone used the Aeromotive 700HP electric pump? any input on it?
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 09-29-2009, 10:55 PM   #17
BossHogg69
motor exploder
BossHogg69's Avatar
another question here too while we're on fuel pumps...
Is there a rough estimate on when you should forego a mechanical pump and use an electric one? I agree with planning ahead for future upgrades (like using -8AN fuel line), but as far as the pump itself goes, when is a mechanical pump out of the question?
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 09-30-2009, 12:01 AM   #18
wheatlandbrawler
my experiences have been if your making over 400whp on a traditional pushrod style fuel pump you start losing fuel... another reason is its been proven that pushrod style fuel pumps cause some parasitic drag resulting in a loss of horsepower, although small amount it does cost ya. and some people struggle with vapor lock with the pushrod pumps. now as far as a MECHANICAL pump in general, mechanical fuel pumps support up 3000hp but they are belt driven and no where near the same lol. just sayin... hope this helps.
Old 09-30-2009, 06:51 AM   #19
djracer
djracer's Avatar
you do know that pump is for injection right.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 09-30-2009, 10:06 AM   #20
BossHogg69
motor exploder
BossHogg69's Avatar
yes Wheatlandbrawler, I was referring to a pushrod type mech. pump. Thanks for deciphering!
Adam
Old 09-30-2009, 11:37 AM   #21
ripdog28
ripdog28's Avatar
DJ, look at it again, it says
-8AN inlet port
-6AN outlet port
Flow exceeds 450 lbs/hour @ 12 volts/45 psi
Fully-submersible for custom in-tank placement
Fuel injected engines:
Up to 700 HP for naturally aspirated
Up to 500 HP for forced air induction
Use regulator #027-13101 or #027-13109
Carbureted engines:
Up to 900 HP for naturally aspirated
Up to 700 HP for forced air induction
Use regulator #027-13204 or #027-13301.
I could be wrong but it said it is good for carb.
69 c-10 BBC
Old 09-30-2009, 02:19 PM   #22
djracer
djracer's Avatar
Maybe it swings both ways. I just saw the high pressure.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 09-30-2009, 06:44 PM   #23
Wild83C10
Wild83C10's Avatar
I am using that one right now. I am very happy with it. It's relatively quiet and works well. I run EFI with almost 40 psi. 4+ years of service and no problems.
I will actually be switching to the A1000 pump since I am switching to a turbo setup.
turbo=
Old 10-01-2009, 12:42 AM   #24
fryco
fryco's Avatar
and don't forget....
Wire it right, use relays, proper gauge wire, and fuses. Soldering and heat shrink are a good thing!!! do not hot wire to a 20amp toggle switch
(although, some people like fires)
i have a magnafuel 500, couldn't tell ya how it works or sounds, i never put fuel into yet... (this winter some time)
fryco is offline   Reply With Quote
Old 10-01-2009, 08:11 AM   #25
djracer
djracer's Avatar
Really anything with a motor needs a relay. Electric Fan, Electric water pump, Electric fuel pump
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
