Old 09-24-2009, 10:40 PM   #1
AusTx68
AusTx68's Avatar
How do you install brake line clips?
Ok, so maybe this is a stupid question..I picked up a set of these line clips along with my SS brake lines from Inlinetube. How do you flare the rivet end after you put them in the frame?
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 09-25-2009, 01:37 AM   #2
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Re: How do you install brake line clips?
Some sort of flare tool I would think. Try contacting Inlinetube and see what they say.
Might be able to flare them with a c clamp???
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 09-25-2009, 02:43 PM   #3
AusTx68
AusTx68's Avatar
Called Inlinetube. They said to place it in the frame and strike it from behind with a punch. It will be fun trying to get these into the crossmember.
Old 09-25-2009, 02:48 PM   #4
wancosc356
wancosc356's Avatar
That sounds good too. Hope you got a few extras for trial and error. Good luck man.
Michael
Old 09-25-2009, 04:42 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
If it's not too late, maybe you should consider another style of clamp. Take a look at these produced by "Made 4 You products" LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-18-2009, 12:36 AM   #6
pritch
pritch's Avatar
I'm a little late, but I just did this same thing, except I re-used my original clips, that I carefully removed on teardown. I had to use plyers and kinda bend the part that sticks through the frame until it just fits in the hole, and then took a center punch tool that would fit into the hole and by prying left and right and up and down, it expanded the thing so that it snugged right up. It worked good.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
