Old 09-25-2009, 01:31 AM   #1
DonsCST
DonsCST's Avatar
Headers on a 4x4
Just installed a new set of JEGS headers on my 70 CST 4x4. They were a little different from the old Headman headers that I took off.
One problem I had was with the #2 spark plug on the drivers side, too close to the pipe. After some heating and bending I gained a liitle more clearance.
The second problem I had was having to bend the z bar for the clutch because the #3 header tube was dead center, again a little heat and a little bending did the trick. No problems on the passenger side.
The rest of the exhaust will be installed by a local shop with flowmaster muffs.
Has anybody dealt with bad fitting headers? Any tips would help. Thanks.
DonsCST is offline   Reply With Quote
Old 09-25-2009, 04:28 AM   #2
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Headers on a 4x4
Hedman Hedders specifies different headers depending on where your clutch cross shaft is located. I found this out when I bought headers for my truck which has a manual transmission. I told them where it was and when I got the headers installed they fit perfectly.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 09-26-2009, 12:27 AM   #3
DonsCST
DonsCST's Avatar
I even called JEGS on the phone to tell them what I had,4x4 ,man. trans. and they said they would fit. Minimum wage work for minimum wage workers I guess. Anyway I think they will work for now, only time will tell, but I will definatelly go back to Headmans on my next project. The Headmans I took off had the #1 tube crossing over the top of 2&3, tons of room.
Old 09-26-2009, 09:09 AM   #4
hgs_notes
GEARHEAD
hgs_notes's Avatar
I just put Hooker Competion headers on my Jimmy and they fit great. I have an automatic and had to bend the shift bar from the column a bit so it wouldn't rub. No sparkplug problems. They also tuck up in the frame pretty good.
hgs_notes is offline   Reply With Quote
Old 09-27-2009, 12:42 AM   #5
Mudder
Mudder's Avatar
Looks like angled boots may be better.
Mudder is offline   Reply With Quote
Old 09-27-2009, 12:48 AM   #6
vectorit
What?
vectorit's Avatar
Good headers ordered for the specific application should require no modifications IMO.
When I ran headers on my K20 burb, I ran Hooker Super Comps and had to do ZERO modifications. In fact they slipped right in with no hassles what so ever.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 12-18-2009, 04:55 PM   #7
JPCY72
what are you guys doing about the crossmemeber? I have a knarly bend in my pipe coming from the collector.....
JPCY72 is offline   Reply With Quote
Old 12-18-2009, 05:47 PM   #8
NYC-10
screamin eagle
NYC-10's Avatar
I used Sanderson headers on my 70 4x4 -no problem
SCREAMIN EAGLE
NYC-10 is offline   Reply With Quote
Old 12-18-2009, 06:22 PM   #9
JPCY72
what part num?
Old 12-20-2009, 12:00 AM   #10
Captainfab
60-66 Nut
The Hedman #69230's are supposed to fit the 4x4's really well. I have a set, but haven't installed them yet. Preliminary fitup to the engine looks good. Clearance for the clutch bellcrank, and good plug access, no passenger side shackle interference, and they don't drop down too low. There's an entire thread on these over on CK5 in the 'Garage' forum.
Old 12-21-2009, 05:30 PM   #11
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea I gotta agree when I buy a good set of headers I want them to fit with out having to do any modifications. I have ran Hooker comp headers and had headmen headers on a rig or 2 and have loved them no major issues plugs are easy and doing a motor swap and putting them back in has been a cake walk!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
