09-25-2009, 10:15 AM | #1 |
NP205 Mount - HELP!!!
I am using an NP205 out of a 1976 k10 to convert my truck to 4wd. I know that there was a bracket that mounted to the side/top on the passenger side from the factory. It mounts to a flat pad with two threaded holes about 3 1/2 inches apart. If i am remembering correctly, it has two metal brackets sandwiched around some rubber isolaters. Does anyone know if anyone makes these aftermarket? The truck i got the t-case from was missing all of the parts and i can't find a single one in a boneyard. Suggestions?
09-25-2009, 10:33 AM | #2 |
Re: NP205 Mount - HELP!!!
There are no after market replacements for the metel pcs that I'm aware of. You can get the rubbers / poly.
I believe I have an extra one around all blasted & painted. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
09-25-2009, 10:41 AM | #3 |
I sent you a PM.
09-25-2009, 10:54 AM | #4 |
saw some here:
http://coloradok5.com/forums/showthr...ighlight=mount |
09-25-2009, 11:00 AM | #5 |
Thanks Cyclone.
09-25-2009, 04:35 PM | #6 |
Everything is work in progress
I'd be interested in one also. The 5K post is a year old
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
09-25-2009, 05:02 PM | #7 |
I believe I have 2 extras but I need to check.
09-25-2009, 05:37 PM | #8 |
I could only find 1. I believe I sold one with a frame a few yrs back. Sorry !
09-25-2009, 06:25 PM | #9 |
Grease Monkey
I have one. PM me if interested
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
09-30-2009, 08:30 AM | #10 |
member
TEEITUP was selling these in a recent post
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
10-03-2009, 07:30 PM | #11 |
help ! trying to put 350 turbo were a 4 sp standard shift was ,turbo has fine spline or 27 teeth i think . 4speed has course spline wright ,do they make a coupling to connect them both together?
10-04-2009, 02:20 PM | #12 |
I believe Advanced adapters makes one for that application. There is no OEM coupling for that.
Gary
10-04-2009, 03:15 PM | #13 |
Not a 205 but I made one for my 203 put in a 59 frame. Rubber pieces are 57 chevy v8 front motor mount bushings available from NAPA for about $7 each.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 10-04-2009 at 03:18 PM. |
