Old 01-15-2003, 01:43 PM   #1
COBALT
COBALT's Avatar
Need flaring & tube bending advice...
I may have to fab up a new fuel line from my mechanical fuel pump up to my little 2gv Rochester 2bbl carb. I'm not going to even think about trying to find a pre-bent line.
Anyone have an angle on a good flaring and bending tool set I could buy? I know I'd use it a lot over the years...
...also where do you guys get tubing for fuel, tranny cooling, brakes, etc?
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 01-15-2003, 02:01 PM   #2
hecticblasts
I usually get the tubing at the parts store,it comes flared at both ends with the fittings.They come in different lenghts,so I'll pick one a little longer that what I need.The racks with the tubing are generally located behind the counter,just ask one of the guys and they'll point you to it.
The tubing bender that I have is made by Rigid,they make plumbing tools and I think The Home Depot carries that line of tools,I bought mine through work from Grainger,it's sturdy and makes some good bends.Harbor Freight has one similar to it but is of very low quality,it will work fine with copper but not steel.
My flaring kit came from Sears,it has all the gizmos to do double flaring,wich you will need if doing brake lines.
I try to mock up the shape of the line with wire(cloth hangers work good)and then use that as a pattern to bend the line.
Before I flare the ends,especially double flares,I take a piece of tubing that I'm not going to use and practice with it a couple times.That way I know exactly how much tubing to let protude for the best looking flare.HF
hecticblasts is offline   Reply With Quote
Old 01-15-2003, 02:16 PM   #3
COBALT
COBALT's Avatar
Cool. Thanks a ton. Time to go shopping...
Seattle, WA.
Old 01-15-2003, 02:21 PM   #4
JimKshortstep4x4
Talking
I got my double flare tool set from Eastwood and it works very well. The inserts for the double flare have the dimensions made into them for measuring the tube length to cut for double flaring. The set will also do single flares. I also, got their tube bender, (the hand bender) and it works well.
Jim
Old 01-15-2003, 10:28 PM   #5
Don Smith
For a long time I cut the tubing for double flares with one of the tube cuttters with the wheel. I recently found out I can make double flares better and with minimal tube clamp marks if I cut the tube with a hack saw instead of tubing cutter and hand file it before making the flare, particularly on the larger dia. tubes.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 01-15-2003, 11:31 PM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
As far as benders go, a set of spring tube benders will work reasonably well. Rather than flaring, when I need to cut off one end of a line I use a compression fitting, as long as it isn't a hydraulic line.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-16-2003, 01:48 AM   #7
Blaze69
Blaze69's Avatar
Hey Fred,
Does the compression fitting work as well as the double flare for brake lines? It would be alot easier......
1969 Blazer: 350/350, 4X4, HEI, Edlebrock carb/intake, dual flowmasters, np205, 3:07's and the rest is mostly stock.
The front end disc swap is finally complete
2002 Z71 Tahoe. CAI, Flowmaster 40, Silverstars in high, low and fogs and a bunch of mods (upgrades) inside and out.
Blaze69 is offline   Reply With Quote
Old 01-16-2003, 04:26 AM   #8
Ed ke6bnl
Originally posted by Blaze69
Hey Fred,
ABSOLUTELY NOT, steel lines need a double flare, stainless steel needs a 37 degree flare with an AN fittings for brake lines and my experience with compression fittings is that they will break easily at the fitting with vibration. I am not fond of compreesion fitting. Just my experience and readings. Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 01-16-2003, 05:59 AM   #9
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here's the Rolls Royce of tubing benders.I've used one.Flares lines like butta.Expensive though(understatement)
click here
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 01-16-2003, 07:54 AM   #10
tim m
When I was doing brake lines, I first bent some 1/4 inch copper, it was a lot cheaper than the stainless. Then when I had the bends right, I used the stainless.
1970 k10
1971 C10
Gilbert Az
tim m is offline   Reply With Quote
Old 01-16-2003, 11:10 AM   #11
Yellow Cheyenne
When doing the double flare the instructions I have tell you to use a file or emery cloth to taper the end that is going to be flared. For me, I've found that to be a fairly important step if you want a successful double flare. If you don't do that, the line tends to split. I use a NAPA flare set.
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
Old 01-16-2003, 11:11 AM   #12
kxmotox247
kxmotox247's Avatar
Hey Fred,
I'm not Fred, but I can tell you that compression fittings work great in brake lines. I work at a machine shop that has a fairly large hyraulics shop too. Our master hydraulic guy says that compression fittings are fine. I did my street rod brake system like that and I had no leaks at any of the compression fittings.
Double flaring sucks.
kxmotox247 is offline   Reply With Quote
Old 01-16-2003, 12:06 PM   #13
Yellow Cheyenne
I'm with Fred ek, I don't think compression fittings should be used on brake lines. Been told many times not to, but can't quote any experts. The way I look at it, if the manufacturers of vehicles won't use them, why would I want to take the chance.
'70 Olds Rallye 350
Old 01-16-2003, 01:12 PM   #14
Fred T
Cantankerous Geezer
Fred T's Avatar
D.O.T. says no compression fittings on brake lines. Double flares only.
Fred
Old 01-16-2003, 01:24 PM   #15
kxmotox247
kxmotox247's Avatar
Not trying to argue here...so don't take it the wrong way.
I've used them for the first time over a year ago on a street rod and haven't had any problems at all. In fact, it made the job of running brake lines from scratch a simple chore. The only leaks I had were from the fittings at the caliper...not where I would have traditionally used a union and possibly had a leak.
What is supposed to be so bad about using them? If the brake line is rigidly secured on both sides of the compression fitting with line clips, how can they vibrate? I can see that if the line isn't supported...that's understandable.
And also, my car, and my truck for that matter aren't daily drivers.
What are the problems?
Like I said, I'm not trying to prove anyone wrong but if they're bad to use, I want to know why and what to look for before I'm driving and my brakes go out.
Old 01-16-2003, 01:50 PM   #16
kxmotox247
kxmotox247's Avatar
....maybe there is a break in the communication. I'm learning that there are two different metals that compression fittings can be made out of....brass and copper.
The copper ones are the type of fittings that can crack or break. I know copper when crack when overflexed. It becomes brittle over time and can break.
The brass ones are the ones that I'm using. I did some internet searching and found some negatives about using them...but no real specifics on failures. Then I came across a website that sell them...for go carts with hydraulic brake lines.
http://www.mfgsupply.com/GoMiniBrakesBrass.html
Here is one guy using them on his truck:
http://www.pavementsucks.com/tech/brakeline.php
In the end, I found lots of sites saying not to use them...so maybe I have a dangerous car then. Some of the same sites also say not to use unions to lengthen a line. I don't know. Anyone have any first hand experience?
Old 01-16-2003, 02:27 PM   #17
COBALT
COBALT's Avatar
...well since this discussion has moved more toward material science and the debate between double flaring and compression fittings I doubt anyone cares that I went ahead and bought the tubing setup from Eastwood Company. lol
Interesting thoughts here though. I've never even considered compression fittings for brake lines (not that I'd run out and replace my lines tomorrow "just to see"), but interesting to think about.
Seattle, WA.
Old 01-16-2003, 02:42 PM   #18
kxmotox247
kxmotox247's Avatar
Well...good move on the purchase anyhow. You can't go wrong by using the double flares.
They were always a pain. I could never get the 2nd flare to come out right. Good luck!
Old 01-16-2003, 07:49 PM   #19
JimKshortstep4x4
Talking
I wanted to second Yellow Cheyenne's comment on filing/forming the end, (taper). It is critical as to whether the first operation will
form the tube correctly or not. Also, a poorly formed chamfer, (taper) can lead to cracking.
I would suggest practicing on a scrap tube before doing the real thing if you have not made a double flare before, just to see how it works. I prefer to use a vise to hold the clamp, but it is not necessary to get a good flare. The nice thing about making your own double flares is that you can duplicate the factory lines as to length, bends, rock guards, etc. I like making brake lines and you can tell if the flares are good or not after you make a few so that you know that they will not leak. I have had to retighten some fittings, but that has happened to me with parts store fittings, also.
Good luck!
Jim
