Old 09-25-2009, 05:15 PM   #1
62 Longbed
62 Longbed's Avatar
Question 62 Fan Shroud ???
Does antbody on here with a 60-62 have a factory fan shroud or was there ever any o.e. ones on our trucks ??? Pictures ??? If they did .. or know where I could find one ... Thanks
62 Longbed is offline   Reply With Quote
Old 09-25-2009, 05:45 PM   #2
63deluxfleet
63deluxfleet's Avatar
Re: 62 Fan Shroud ???
i haven't seen one but here is one on summit: http://www.summitracing.com/parts/SUM-381101/
A girl phoned me the other day and said... Come on over, there's nobody home. I went over. Nobody was home. -Rodney Dangerfield
.......THE ROAD TO HELL IS PAVED WITH GOOD INTENTIONS.....
63deluxfleet is offline   Reply With Quote
Old 09-25-2009, 07:32 PM   #3
62 short step
62 short step's Avatar
Here is a pic for you.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 09-25-2009, 07:45 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
WOW! That thing is crazy. It looks like the factory was using half shells from 55 gal drums!
Old 09-26-2009, 01:24 AM   #5
Captainfab
60-66 Nut
Yeah they don't look as nice as the '63-'66 shrouds.
Old 09-26-2009, 06:11 PM   #6
62 Longbed
62 Longbed's Avatar
Thank You for the picture !!! Wow!! Thats some fan shroud .. but now I have an idea what to look for ..
Old 09-26-2009, 07:37 PM   #7
62 short step
No problem!
1965 c-10
86 chevy c/k 20
Old 01-03-2011, 07:00 PM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
That thing is hilarious!
Motivates me to just make my own
66 C20 Service Truck:
Old 01-04-2011, 02:28 PM   #9
1960project
1960project's Avatar
I got 2 original fan shrouds that fits 60-62 and I would be willing to part with one of them. Both are in excellent condition. I searched for 20 years to run up on these 2...very rare.
1960project is offline   Reply With Quote
Old 01-04-2011, 05:16 PM   #10
jchav62
1962 C-10
jchav62's Avatar
I had mine chrome plated...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 01-04-2011, 06:22 PM   #11
LostMy65
LostMy65's Avatar
Okay,
Now I want one.
That looks so cool, and it still looks classic.
What's that stamp plate on it at the top?
I'm thinking now that the 55 gal drum cut to size and then chromed wouldn't look so bad after all.
Old 01-04-2011, 07:43 PM   #12
jchav62
1962 C-10
jchav62's Avatar
Originally Posted by LostMy65 View Post
Okay,
Now I want one.
It's a metal valve cover decal... "Chevrolet 327 Turbo Fire" I riveted on there..
Joseph Chavez
Old 01-04-2011, 08:27 PM   #13
LostMy65
LostMy65's Avatar
^ It looked so official.
Old 01-04-2011, 08:30 PM   #14
LostMy65
LostMy65's Avatar
You guys won't believe it.
I just found the makings of an old 62 Shroud right in my own backyard:
Old 01-05-2011, 10:16 AM   #15
jchav62
1962 C-10
jchav62's Avatar
Nice!!
Joseph Chavez
Old 10-12-2012, 01:42 AM   #16
LostMy65
LostMy65's Avatar
This 58 shroud is very similar:
(not mine)
http://www.ebay.com/itm/360495739928...84.m1423.l2649
Old 10-12-2012, 11:23 AM   #17
62 Longbed
62 Longbed's Avatar
I have a 64-66 Plastic / fiberglass fan shroud with a couple splits that I will part with if it would fit what your working on ... Can post pictures later
Old 10-12-2012, 06:17 PM   #18
Brad54
Brad54's Avatar
That's the "standard" shroud, for regular radiator and manual-trans vehicles.
There are actually three different shrouds available for '60-'62 trucks.
Manual-trans 1/2-ton, early version, is shown upper left.
I've found one of those in a junkyard on an untouched '60 or '61... it was rotted away, so I left it, but it's the same one shown.
What I think is a later 1/2-ton shroud ('62, maybe '61) is the one on the upper right. The barrel at the radiator is wider than the mouth at the fan, so it covers more area on the radiator.
If you have an original automatic trans truck, you also got a bigger radiator, and it had the trans cooler built into it.
The automatic shroud is a full shroud that covers the whole radiator, has a notch at the bottom corner for the trans cooler lines, and attaches to tabs brazed onto the mounting flange of the radiator. Shown on bottom.
The other two don't cover the whole face of the radiator, and they mount using the six bolts that hold the radiator to the core support.
The auto-trans radiator and the 3/4-ton and up radiator are wider and a little taller, but are a direct bolt-in to a 1/2-ton '60-'62 truck. The core support, at least on my '61 Suburban, has the blind nuts in place for both radiators. They made-up the difference in the width of the core by making the mounting flanges narrower, thus keeping the mounting bolts in the same location, but put one farther down the core support.
Over a couple years, I scored all three of these shrouds... I put a 3/4-ton 4-row radiator in my '61 Suburban, and kept the full auto-trans shroud for it.
I got a repro heavy-duty 7-blade clutch fan from YearOne--the application was big-block Mopar with A/C. The Chevy and Mopar fans interchange... I got the largest diameter one, which filled the opening in the shroud the best. It was a toss-up between BBC with A/C and BBM with A/C... the Mopar was a little larger in diameter.
Spend the money for an authorized reproduction fan! The generic aftermarket fan had a warning sticker on it that said not to exceed 4,000rpm.
It's been a few years, and I never got around to making the mounting tabs for the shroud. The HD fan and 4-row radiator has kept my truck cool in Atlanta traffic in the summer. The fan, even set so far back, pulls enough air at idle to suck a piece of paper tight to the radiator from the front. It moves a LOT of air.
I expect it to pull birds out of the sky once I finally get the shroud on.
I just found another auto-trans full shroud and snapped it up. Shoot me a PM if anyone is interested.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 10-12-2012, 08:09 PM   #19
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
My shroud is stock but was trimmed to allow my set up to fit correctly with the W/P and billet serp pulleys. I have a 1 inch spacer block in my set up, I swapped out the flex fan for a clutch fan , no temp change just could not stand the flex fan noise..
GMR-PERFORMANCE is offline   Reply With Quote
Old 10-13-2012, 12:39 AM   #20
Captainfab
60-66 Nut
Thank you Brad54 for the great info on the '60-'62 fan shrouds
Old 12-12-2012, 10:28 PM   #21
Evan's 1965
Evan's 1965's Avatar
http://evansville.craigslist.org/pts/3437700472.html
Evan's 1965 is offline   Reply With Quote
Old 12-21-2012, 07:01 PM   #22
LostMy65
LostMy65's Avatar
My 62 shroud arrived today.
I didn't remember the one I had from the 62 gmc donor having a taper.
Old 12-21-2012, 07:37 PM   #23
Brad54
Brad54's Avatar
I very clearly remember the one I had like that tapering.
Congrats on getting it!
I pulled one out of a '62 dump truck, thinking it was the same. Nope. I can probably cut it down to work and still look right. I may, if I get bored and run out of projects in the shop!
Otherwise I'll just use the nice auto-trans version I have.
-Brad
Old 12-21-2012, 07:54 PM   #24
LostMy65
LostMy65's Avatar
Thanks for the Congrats and confirmation regarding the taper.
It's been 25+ years since I saw the shroud I had. It most likely was tapered and I just never noticed.
Old 12-22-2012, 08:34 PM   #25
hotrodder
Thumbs up Re: 62 Fan Shroud ???
What is the difference in the one for a 63? I need one for my truck. It has a 283.
hotrodder is offline   Reply With Quote
