Old 09-25-2009, 11:18 PM   #1
old Chevy guy
old Chevy guy's Avatar
Seat swaps?
My father has an 86 pickup 3/4 heavy duty.Its in pretty good shape and all but due to the ride height and that the seat is kind of worn out he is having a hard time getting in and out. I posted an ad on craigs list looking for a good used seat and got a few responces.So after all the background here is the question.Will a seat from a newer truck an 88 2500 fit in the 86 without a lot of mods?and what about buckets from a 87 suberban with they fit other than a few extra holes?What about a 67-72 seat? thanks for any info.
old Chevy guy is offline   Reply With Quote
Old 09-25-2009, 11:29 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Seat swaps?
the newer bench seats work with modify the 86 bench seat bracket and for the burb seat you''ll need the seat bracket off the burb, two of the seat tabs weld on the cab floor
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-26-2009, 12:40 AM   #3
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: Seat swaps?
A trick I learned from a fellow member...See if you can find a rear seat out of a crew cab. They are the same seat and are usually hardly worn.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 09-26-2009, 09:32 AM   #4
JohnC
JohnC's Avatar
Re: Seat swaps?
My 84 has a 88-94 seat in it. Doesn't seem to have any mods to the mounting point on the floor. So I don't know where they modified it at.
JohnC is offline   Reply With Quote
Old 09-26-2009, 09:41 PM   #5
old Chevy guy
Re: Seat swaps?
Cool info. can anyone chime in about 67-72 seat? Also the tabs that are welded on the floor for burb buckets,I dont think the guy is going to have them is it something I could fab,pictures anyone?
Old 09-26-2009, 11:10 PM   #6
Driveway Dreams
I have car A.D.D.
Re: Seat swaps?
From what I have been told. You are much better off (from the effort standpoint) if you can get the floor pan section from a Burb. Then just cut out and weld in the bracing you need.
-Gerald
Old 09-27-2009, 12:06 AM   #7
Storm Chaser
Storm Chaser's Avatar
Re: Seat swaps?
Don't know if were talking buckets or bench, so everything I'm saying is assuming bench...
Something in the mounting between the seat bracket (slider) and the seat had to have been done. Seat brackets for 88-98 are much taller than those of a 73-87. On a 73-87, the bracket is made in such a way that the slider portion is pretty much right on top of the floor pan, so the seat is only an inch or two above the floor at the outer edges. On the 88-98 seats, the slider is attached to stands, so the seat is higher than the floor by probably 6 inches or so.
I tried to put an 89 seat into a 78, and found out that the stands were just too tall, not to mention there was a floor contour problem. So I figured I'd just mount the 89 seat to the 78 slider mechanism and solve the height problem... then found out that the bolt holes were way off, so I had to do some fabbing to pull it off. When all is said and done, the 88-98 seat is slightly narrower than the seat from a 73-87, but not really enough to matter.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 09-27-2009, 06:03 PM   #8
old Chevy guy
Re: Seat swaps?
Thanks guys anybody know about 67-72 seats in a 86. Im leaning toward some burb buckets I found with a console but I also have here two really nice almost like new 67-72 benches.Id check it out myself but I don't want to take the seat out of the 86 till I can put something right back,maybe I'm lazy but I'd hate to pull it out and find out it won't work and put the old one back in. Especialy if someone can tell me thats been there and done that,Right? Thanks
Old 09-28-2009, 12:58 AM   #9
Storm Chaser
Re: Seat swaps?
I used to have a few of the 68-72 trucks, but I'll be darned if I can remember how their seat mounts were. I'm pretty sure they were short and close to the floor, similar to the 73-87 trucks, but I doubt very seriously that it will be a bolt-in without some form of modification. It might be as simple as drilling new holes, or it might be more involved. When the body style changes, the floorpan layout changes with it. If you've got decent fab skills, a seat swap shouldn't take very long, even if you have to fab something up.
1988 R2500 Crew Cab
Future plans-
Old 09-28-2009, 01:39 AM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Seat swaps?
Look for Dodge Ram seats. I think in 99, the seatbelt was moved to the seat. Prior years had belts on the cab pillar. The seats are large. The center console is HUGE!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
