09-26-2009, 10:46 AM | #1 |
Gas tank vent?
I installed a 1970's car gas tank under the back of my 53. It has 2 lines coming out by the sending unit. One is the 3/8 line to feed the engine, the other originaly went to the return line from the fuel pump I think. I know they also had a charcoal canister for a vent to go to. I am running a fuel pump with one inlet and one outlet, no return line. What should I do with the second line at the tank. I would like it to vent somehow so I don't get a vacume in the tank, but I think it would be a bad idea to let gas fume just flow under the truck. Is there a filter to cap this line? My gas cap has no vent either. Thanks.
09-26-2009, 04:44 PM | #2 |
and a few others
Re: Gas tank vent?
Doesn't that return line go as "deep" in the tank as the suction line? If so, I would worry about a siphon effect if you used it as a vent, unless there's an inline check valve still there.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
09-26-2009, 11:37 PM | #3 |
Re: Gas tank vent?
If its a true vent run a hose with a roll over filter used for racers up the nearest stake pocket. If it is as deep as the pickup line then just cap it off with a hose and fitting and run a vented cap. If the inlet is out the back you may run into problems going up steep hills, I had a late 60's chevy tank as a second tank in mine. In hilly country had to make sure I was running off the main tank and had a non vent cap on the back. Around town did not have any problems as long as the tank was down a few gallons.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
09-27-2009, 08:41 AM | #4 |
Re: Gas tank vent?
i would just cap it off and add a vented gas cap
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
09-27-2009, 11:08 AM | #5 |
Re: Gas tank vent?
http://www.yogisinc.com/detail.cfm/-...m=Yes/zoom.htm
This is the type of cap I alread have. The return line stops at the yery top of the tank. My cap is already installed, and I would like to leave it if I can. Is there some kind of one way valve for a vacume line I can put on the end of that vent line? I know power brake boosters use a one way valve, maybe I could make one of those work. |
09-27-2009, 11:27 AM | #6 |
and a few others
Re: Gas tank vent?
I'm not sure you'd want to go that route. I think you need PV venting (pressure & vacuum) otherwise, what will happen if you fill the tank and night when it's cool outside, then park it in the daytime sun?
09-27-2009, 01:19 PM | #7 | |
Re: Gas tank vent?
http://www.summitracing.com/parts/BOB-90921/ There are at least half a dozen more there.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 09-27-2009 at 01:20 PM. |
09-29-2009, 12:38 PM | #8 |
Re: Gas tank vent?
Im getting ready to plan out my fuel system and Im going to be running an under bed tank. Im I ok with running a vented gas cap or should I tap the tank and plumb in a rollover vent/valve? Can the rubber hose be run below the tank or should it stay above the level of the tank in the fender well?
http://www.yogisinc.com/Detail.cfm/-...vv/product.htm |
09-29-2009, 02:11 PM | #9 | |
Tripple Five Fanatic
Re: Gas tank vent?
Tri5 |
09-29-2009, 02:18 PM | #10 |
Re: Gas tank vent?
I dont mean to hijack, but the reason I asked, is im gona run a pump similar to the tanks inc pump and I figured I should vent the tank. The screw in tank vent stops fuel from pouring out if ever turned over but mainly serves as a vent for fumes to exit the tank.
Any info on routing the vent tube? |
