09-26-2009, 03:57 PM | #1 |
Exhaust size
What are you guys running for dual exhaust systems? Lookin to see what most guys are running, mine has 2 1/4 seems extremely popular wiht these style trucks, problem is my 4 banger s10 system is louder than my k20 true dual system same exact flowmaster 40 series muffler?? Anyone running a 3 inch system, or will that hurt the motor hp more than help it??
Once a Marine Always a Marine OOH-RAH GM Fanatic 1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!" 1986 c30 camper special 454, th400 (for sale) 1984 K10 Big Ten (project) needs motor 1984 C10 355, 700r4, (project) needs shortbox bed |
09-26-2009, 06:27 PM | #3 |
Re: Exhaust size
On my 73 BBC I have Long Tube headers to a stainless summit X-pipe to 3" pipe I cant remember what series of flowmasters to 4 inch tips dumping right over the rear end, it is actually quiet compared to my 77 SBC that just has 2 1/4 to Flowmasters 40 series to turndowns. The X-pipe quiets it down alot, until the cutouts are off.
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
09-26-2009, 08:03 PM | #4 |
At the body shop.
Re: Exhaust size
The engine matters as much as the mufflers. I took some 2 chamber flowmasters off of my 9.5:1 400 sbc because it was too loud and gave them to a friend with a stock bbc and it was quiet
09-27-2009, 12:19 AM | #5 |
Re: Exhaust size
i have/had a 3" system on my stock bolt-ons only crate 350 and i KNOW i lost some torque. you need to be putting out some power to run 3" all the way back in my opinion...
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
09-27-2009, 09:31 AM | #6 |
Re: Exhaust size
So what would everyone recommend for a pretty much stock 454? 2 1/4, 3?
I believe it has 3 on it now but the pipe is in bad shape and has glasspacks that dump right before the rear axle. Hate the sound of it :\ |
09-27-2009, 11:57 PM | #7 |
Re: Exhaust size
Most stock 454's seem to come from the factory with a 2.5" system. If you're staying stock and running duals go with 2.5, high flow mufflers and run the exhaust over the rear axle. Dumping exhaust gases under the truck isn't a sound practice IMO.
09-28-2009, 11:50 AM | #8 |
Re: Exhaust size
How will the 2.5 do with a smaller 350 motor is the question now. Plan is to ditch this 454 sooner rather then later but I obviously need an exhaust system until I do that.
I agree that dumping under the truck isn't a good idea but that's how the truck came and its on my fix list |
09-28-2009, 12:16 PM | #9 |
Re: Exhaust size
Dual 2.5" on a stock/mild 350 is good, I ran dual 3" and lost power, but gained a great sound.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
09-28-2009, 11:38 PM | #10 |
Re: Exhaust size
I had 2.5" dual run into 3" mufflers. sounded damn near the same as 3" run into the same mufflers. Just not quite as loud.
'79' shortbed |
09-29-2009, 08:24 PM | #11 |
Slugish
Re: Exhaust size
3 in collecter from headers > to 3 in high flow cat > to one flowmaster ( don't know what sereies) 2 2.5 pipes coming out . sounds & performs great . there is something to overkill on to big an exhaust . I would say unless yoiu have 500 plus horses , stay with 2.4-2.5 out the back .
Oh , 408 warmed up , but nothing crazy |
09-30-2009, 09:23 AM | #12 |
On a budget like Fred Sanford
Re: Exhaust size
I'm running 3" duals into super 44's dumped under the bed. I won't be sneaking up on anybody, that's for sure.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
09-30-2009, 12:08 PM | #13 |
Re: Exhaust size
Ran 2.5 with 40 series flowmasters on my 350 and didn't change any thing when I went to the 454. Just had to shorten the pipe due to long tube headers but the setup sounds great on both motors
You cant compare a 4 banger to a big block. My Accord also has 2.5 from header back with a 40 series and it is much louder than the truck.
1949 Five Window, 1973 Step Side, 2000 Z71 |
