09-26-2009, 04:41 PM | #1 |
draining coolant
I need to change my block heater on my 2006 5.3L half ton. does anyone know where the radiator drain plug is and also the block drain plugs? ( I can't believe I would ever have to ask such a question) Thanks in advance.
09-26-2009, 06:09 PM | #2 |
Re: draining coolant
Not realley it will still leave guild in the block bit you have to drain it anyway u willl loose some changing the blocker heater
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
09-27-2009, 09:47 AM | #3 |
These trucks do not have a coolant drain. Just remove the lower radiator hose and quick point it into a 5 gallon bucket. That's all you can do.
09-27-2009, 03:18 PM | #4 |
thanks for the info...... so they don't have block drain plugs either? Seems logical. Thanks again
09-28-2009, 02:36 AM | #5 |
Wow, that sounds messy...for another $4 or so they could have put a drain plug in the radiator...too bad.
_____________________________________________ 1960 F100 (soon to be SBC/700R4) 2005 GMC Sierra |
