09-26-2009, 10:14 PM | #1 |
At the body shop.
Low budget electric fan
I did some junk yard crawling the other day. The fan is out of 99 jeep cherokee
09-26-2009, 10:28 PM | #3 |
At the body shop.
Re: Low budget electric fan
You can kind of see the tab on the shroud The fan had 3 tabs on it 2 toward the side 1 on the bottom I cut a 45 degree piece of tubing and bolted thru the shroud and simple L bracket on the bottom Its wired to switch where the tank selector should be
09-26-2009, 10:42 PM | #5 |
At the body shop.
09-26-2009, 10:44 PM | #6 |
Badass
lol nice
how much was it at the junkyard
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 Last edited by 3r!c84; 09-26-2009 at 10:44 PM. |
09-26-2009, 10:48 PM | #7 |
Sure does look like it's supposed to be there, don't it? That's the factory shroud, right?
1988 R2500 Crew Cab Immediate plans- get it running! Future plans- Rear disc swap & Hydroboost Dually conversion with shackle flip-n-switch 4x4 conversion with 52" springs Maybe some new body panels Who needs a car when they make crew cab trucks? |
09-26-2009, 10:49 PM | #8 |
At the body shop.
10$ and it keeps my 400 cool at 100 degree days in cali
" That didnt make it any newer " " Dont antique the equipment " |
09-26-2009, 11:49 PM | #10 |
At the body shop.
Yep thats a factory big block shroud drilled two holes in it to mount the fan
