Old 09-26-2009, 11:31 PM   #1
72chevyk10
I built it
72chevyk10's Avatar
shift kit install
how hard is one to put in? ive got a th350 and have never even seen the inside of an automatic tranny. would i be able to put it in by myself? any recomdations on a brand of shift kit to get?
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 09-26-2009, 11:54 PM   #2
nsuengineer06
nsuengineer06's Avatar
Re: shift kit install
I think B&M has some good kits. They have one called a B&M in a box. It is basically everything they put in theirs boxed up so you can put it in. If i'm not mistaken it comes with very detailed instructions for each step and they also offer all the specialized tools needed. Might be a good starting point to look at.
1967 C10 LWB 454/TH400
1971 C10 SWB
1984 C30 LWB Dually 454/4 spd 4:10
2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison
nsuengineer06 is offline   Reply With Quote
Old 09-27-2009, 12:30 AM   #3
GruntMoanCough
GruntMoanCough's Avatar
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 09-27-2009, 02:22 AM   #4
mclairmo
I installed one in a Ford C4 and it was easy, but time consuming. Make sure to read the instructions online or have them e-mailed or faxed to you before you buy so you can determine if you really can do it and if you have the tools to do it. I was going to rebuild my TH400 in my Camaro until I saw a video on how to do it and determined I did not have all of the tools to do it.
mclairmo is offline   Reply With Quote
Old 09-27-2009, 03:47 AM   #5
jkeady
jkeady's Avatar
I've done several, and B&M's street/strip "shift improver" kit for the TH350 is easy as falling off a log. Easier than the Ford AOD kit (which is really easy too). There were some poorly-photocopied instructions in the package with the one I got, but they were sufficient.
The name of the game when working with an automatic transmission: cleanliness. Work in a clean environment, use clean ATF when it's called for, and if you don't have a torque wrench that measures inch-pounds, do your damnedest to torque the valve body bolts uniformly. Oh, and you will be covered in transmission fluid, there's no getting around that.
Josh
'70 Custom Camper / 20
jkeady is offline   Reply With Quote
Old 09-30-2009, 04:42 PM   #6
72chevyk10
I built it
72chevyk10's Avatar
cool, thanks ya'll ill look into that B&M kit. i just really want to be able to feel the thing shift the only way i can tell its shifting is the drops in rpm
Old 09-30-2009, 05:31 PM   #7
drunkbus
New Member
drunkbus's Avatar
I've had 2 TH350's rebuilt and shift kits installed by 2 different professional shops and they both used Transgo shift kits and I was happy with them.
http://www.transgo.com/
drunkbus is offline   Reply With Quote
