09-27-2009, 03:07 AM | #1 |
profeshinaly unimployed
i hate doin brake work
i think my piston on the passenger side is messed up cuz no matter how hard i turn the table vice the piston wont go in at all so is there some kind of trick that im missing?
"having mud flaps is like asking for a smaller trophy" |
09-27-2009, 04:05 AM | #2 |
Re: i hate doin brake work
Are you sure the vice isnt hitting the caliper? Ive never used a vice for pushing a piston back in. Try a C clamp and use one of your old pads. If it doesn't want to go back in, you need to buy a new caliper.
1976 Chevy 1/2T 2wd SWB 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com |
09-27-2009, 09:40 AM | #3 |
The One And Only !!!
Bingo ^^^ The use of a vise may cause the piston to cock in the bore and jam it up, It needs to have even pressure to slide back in.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
09-27-2009, 11:21 AM | #4 |
Robert Olson Transport
the other thing that you need to check is if the c clamp doesnt work disconnect the caliper from the rubber line and try it then.. Ive heard stories of lines collapsing and not letting the fluid out of the caliper...
and yes poke brake work can definately suck lol
09-27-2009, 12:31 PM | #5 |
It'd be alot cooler if you did
You can put in all new lines, calipers, pads, and rotors for under $200. Do it right!
